Gas Tank leak on 91 integra
Old Dec 13, 2011 | 06:28 PM
charliewolf_0's Avatar
Icon2 Gas Tank leak on 91 integra
So I bought a 91 integra that has caused me a lot of problems but this last one I didn't expect.i finally had fixed the oil pan, replaced knock sensor on b16, got a new clutch, new tranny, intake, and battery. Got the car running and went to fill up the car. As soon as I got to the 8th gallon, I noticed gas coming from under the car. When I got home I lifted the car to see if I could see where the leak was coming from, but as soon as I lifted the rear gas came pouring out . So this weekend I will attempt to change the gas tank. I have read some basics on how to do it, never worked on this area of the car. Just wondering if you guys think it is easy enough to do myself? Any tips on how to do it? Anything I should look out for? Anything advise would be helpful. Thanks
Old Dec 13, 2011 | 08:58 PM
mcnos's Avatar
Default Re: Gas Tank leak on 91 integra
Be wary of gas getting in your eyes.
Don't pinch,break any lines. Make sure nothing can make spark around you. Would help with a friend to help you. I think it MIGHT have a drain for the gas tank but i'm not sure until you get under there. Stuff will be hard to remove but is not impossible. Use flarenut wrenches on lines for sure.
Buy a Helm. I could be wrong, but there should be two straps that hold the gas tank up as a support, but could be different. This is from a 87 accord and 92 prelude gas tank removal I've done.
VTEC_Viking
Jul 30, 2008 09:33 AM
ironchef25
Jun 15, 2004 04:18 PM
PRS395
11
Mar 7, 2003 07:29 PM
madchiller
Aug 30, 2001 12:47 PM
