weird coolant leak in B18b1
Old Dec 13, 2011 | 05:24 PM
sfar785's Avatar
Default weird coolant leak in B18b1
Ok, so i parked my car today and saw smoke coming from the bay, i shut the car off and i popped the hood just to see coolant pouring out of my water pump. I let it sit for 2 hours and then went back out to see what was wrong. I filled it back up with water and started the car, didn't see any more leaks or anything. My radiator took about 3/4 a gallon of water, so it wasn't completely empty. I'm going to replace my water pump tomorrow but what my question is "what could have leaked and then just stopped?"
btw, my car is a 93 Civic with a b18b1 swap.
any help is appriceated!
oh yeah, i did use the search and i even googled, i found nothing related to Integra motors.
Old Dec 13, 2011 | 06:04 PM
mark@silbernage's Avatar
Default Re: weird coolant leak in B18b1
Seals probably going, but not completely gone. There is normally a pressure spike right after you turn off the engine, as the heat no longer has anywhere to go (coolant not circulating)... so, that's often when you see the leak. At other times, with lower pressures, no visible leak.
Tomorrow's work should take care of it!
Old Dec 13, 2011 | 08:00 PM
sfar785's Avatar
Thanks so much! That does explain why it would do it. So should I replace just the seal or the whole pump? I hear that just replacing the seal would work but I'm not sure about the mileage on the pump itself, I'd rather be safe than sorry.
Old Dec 14, 2011 | 12:40 AM
seanbev24's Avatar
You need to replace the pump and seal. Replace the timing belt while you're in there and closely inspect the front crank/cam seals. If there's any leakage, replace those too.
Old Dec 14, 2011 | 06:27 AM
sfar785's Avatar
woke up this morning to pouring rain...i have off work tomorrow morning and it's supposed to be sunny, i might just get the parts today and hold off on fixing the car until i don't have to do it under an umbrella
Old Dec 14, 2011 | 01:47 PM
sfar785's Avatar
replaced the pump today....the old one had some shaft play and gritty feeling in the bearings, not to mention the seal was all sorts of nasty lookin
Old Dec 14, 2011 | 02:02 PM
sebTeggy's Avatar
pics!
did u end up doing ur timing belt?
Old Dec 15, 2011 | 11:39 AM
sfar785's Avatar
my timing belt was already replaced, just never replaced the water pump...which i should have done
anyway, nothing special about my bay, still need to put my header on but this weather doesn't want me to
sfar785
Dec 14, 2011 01:46 PM
flipldls
May 9, 2010 02:14 PM
TylerLorenz
May 31, 2009 07:30 AM
spicoli
15
Mar 11, 2005 06:56 AM
