weird noise from cluster area ??
Old Dec 13, 2011 | 01:26 PM
ef9tuner's Avatar
Icon2 weird noise from cluster area ??
What up h-t I have a weird noise coming from my driver side area/cluster area so when I'm driving I hit around 35-4000 rpm I get a buzzing/ grinding noise even when i let go of the gas hit the same rpm it buzzes I am not sure what it is has anyone had this problem any input is appreciated thanks
Old Dec 13, 2011 | 02:04 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: weird noise from cluster area ??
Rephrase everything you just said so it makes sense.
Does it happen while moving and/or sitting still?
You let off the gas when - while you are moving?
Almost sounds like something is just vibrating in your dash somewhere; until a better description is given it's hard to say.
crxguy406's Avatar
Maybe your speedo cable is starting to fray?
Old Dec 13, 2011 | 03:23 PM
crvtectim's Avatar
Maybe it's just a 20 something year old car with some... good vibrations.
Stock rubber motor mounts?
Old Dec 13, 2011 | 10:28 PM
ef9tuner's Avatar
Ok while I'm driving and not driving I can be on neutral and it still buzzes and when I'm driving same buzz I don't think its speedily cable because it does it when I don't drive hasport mounts no vibration so I don't think its the mounts ??
Old Dec 14, 2011 | 01:28 PM
ef9tuner's Avatar
Bump
djay86
Jun 25, 2010 11:24 PM
4everVtec
Oct 10, 2007 10:36 AM
92integraVTECgsr
Dec 22, 2004 04:25 PM
ACRProject
12
Oct 15, 2004 01:57 PM
CivicBoi
Mar 17, 2003 06:09 PM
