1998 Civic LX will not start- Security Issues
Old Dec 13, 2011 | 11:37 AM
lponcian5799's Avatar
Default 1998 Civic LX will not start- Security Issues
Hey guys, I'm not a n00b to this first of all.
I have had a lot of issues with the security system before. As you can see, I just opted for removing it all together from behind the cup holders. But now the car won't start at all. I'm a bit rusty with my car knowledge and I can't ID the problem here.
Is it a faulty starter? faulty distributor? faulty battery?
Video here to help you guys. All suggestions are very super uber welcome!
http://youtu.be/2AfGsV7_eSs
Old Dec 13, 2011 | 11:46 AM
sfar785's Avatar
Default Re: 1998 Civic LX will not start- Security Issues
sounds like a shitty battery to me, it's not even getting enough juice to crank your starter
Old Dec 13, 2011 | 01:14 PM
grumblemarc's Avatar
The Grumpiest
Sounds like it. Take the battery to get tested.
Old Dec 13, 2011 | 01:59 PM
FAMz_DOMANi_MB4's Avatar
does your car has a alarm with a kill switch
Old Dec 13, 2011 | 02:21 PM
I have a kill switch for my gas, but I haven't touched it. Don't think that would have anything to do with it.
Could it be the battery even though every time I crank it, it's being jump started?
Old Dec 13, 2011 | 02:34 PM
sounds like bad grounding or bad wiring somewhere, the starter is not getting enough power to start
Old Dec 13, 2011 | 04:30 PM
I am leaning towards bad battery. But was also thinking distributor since I have tried this so many times to no avail. Maybe I fried the distributor?
Old Dec 14, 2011 | 04:26 AM
Bump for more suggestions!
Old Dec 14, 2011 | 05:41 AM
alphalanos's Avatar
see if you can put a jump box on it. Sometimes using cables wont work. If it fires right up with a jump box, then its the batt. Put a batt in then get the alt tested to make sure.
jump box
Old Dec 14, 2011 | 05:43 AM
BobbyRodriguez's Avatar
Buy a new car!
Old Dec 14, 2011 | 05:46 AM
The Grumpiest
Can you push start it?
Old Dec 14, 2011 | 05:53 AM
alphalanos's Avatar
its auto i doubt it will
Old Dec 14, 2011 | 06:06 AM
The Grumpiest
Dammit. And I saw that in the vid too. Then I'm back to the battery.
Old Dec 14, 2011 | 06:11 AM
sfar785's Avatar
bad dizzy wouldn't cause it to crank like that, that's a battery issue
honda001
Acura TL, RL & ZDX
Sep 20, 2013 06:59 PM
viciousef9
Feb 20, 2008 03:47 PM
Senbonzakura
Apr 16, 2006 08:27 PM
tan2
Nov 4, 2002 10:10 AM
