flushing radiator
Old Dec 13, 2011 | 11:11 AM
playertwo's Avatar
Default flushing radiator
Sup yall, I'm trying to flush my radiator and the directions state I should turn my heater all the way up. The problem is I don't have a climate control, is it alright if I jumped the fans instead?
Old Dec 13, 2011 | 11:52 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: flushing radiator
What does jumpering the fans have to do with that? The purpose of turning the heater "all the way up" is because some vehicles won't flow coolant through the heater core unless the heat is on. This could be due to the way the coolant is let in through a valve; be it controlled by vacuum, electronic, or mechanically. On '88-91 Civic/CRX's they use a mechanical valve hooked up to the climate control **** that controls temperature.
Now that that's out of the way... The purpose of turning the heat on is so that no air pockets will form in the heater core and cause cooling system problems down the road. I assume that since you have no climate control - you have no heater core either. If you still do you can just manually open the valve from the engine bay. If you don't this section doesn't apply to you and your process.
Old Dec 13, 2011 | 12:07 PM
playertwo's Avatar
I have the heater core. I just took out the climate control cause it was broken in half and was waiting to get a new one. So how would i manually turn on the heater?
Old Dec 13, 2011 | 01:21 PM
playertwo's Avatar
I just need to figure out how to turn the fan blower on, is it possible?
Old Dec 13, 2011 | 01:43 PM
miguey310's Avatar
the point of turn the heater on is to make the thermostat open faster or you can just open the bleeder screw
Old Dec 13, 2011 | 01:59 PM
DO IT ON ALL FOURS
This is almost sig worthy...
Old Dec 13, 2011 | 02:36 PM
crvtectim's Avatar
... lol
xlusiveracer
30
Feb 10, 2017 11:49 AM
supertiggy
Feb 26, 2009 09:15 AM
fallmartin
Dec 2, 2008 05:01 PM
jadugartir
12
Nov 10, 2006 10:18 AM
scratchline20
Jun 21, 2003 08:29 AM
