Bent rear subframe - can this be fixed?
my rear subframe on my civic was bent in an accident. do you guys think this could be fixed
nope i got ran off road and curb checked hard......well the rest of the car is fine just the sub frame bent. i was hoping i could probably weld a new one on
holy ****....like everyone else said, it CAN be fixed but with the price a shop will charge you just buy a new shell. Or sell/part out what you got and start from scratch, although that should be a last resort.
I've seen rear subframes get cut off cars and new ones welded in but:
- It's high risk (if it's not welded back right then it's not going to fit or drive right still)
- It's possibly not safe
- It could be expensive
- It does look like there could be damage into the cabin, so a repair might be impossible
So you could end up spending a lot of money to make a car possibly unsafe to drive.
The OE piece appears to be about $190. If you were to use a donor car then you need to cut out more than that part in order to have a good donor piece that you can trim up and fit to your car.
I'd get rid of the car (part it out unless you can do an insurance claim) and get a new one. Also get some new tires.
