Difference between HX and DX/LX/CX Exhaust manifold/ Cat Converters?
Old Dec 13, 2011 | 08:53 AM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
Default Difference between HX and DX/LX/CX Exhaust manifold/ Cat Converters?
The exhaust manifold on my 1997 Civic HX broke. The car is out of the extended emissions warranty so I need to replace myself.
I found a local guy who has several manifolds off a D16Y7.
I am pretty sure they will fit as they all have the same aftermarket Doorman PN, but according to parts websites (OEM honda) there is a difference: HX = 18160-P2M-A02 where as the others use a 18160-P2E-A12
Can anyone confirm that yes the DX/LX/CX manifolds are the same, and yes they will fit on a HX?
thank you!
Old Dec 13, 2011 | 09:01 AM
sfar785's Avatar
Default Re: Difference between HX and DX/LX/CX Exhaust manifold/ Cat Converters?
my roommate had an EK DX with the Y7 with an exhaust manifold leak so we put an exhaust from an LX with a Y7 on it
Old Dec 13, 2011 | 09:05 AM
nytosc's Avatar
And that fit fine? I was looking at OEM part numbers, and they are in fact the same between the DX LX etc so I believe that is confirmed.
Big question now is will one of the above fit onto a HX?
Old Dec 13, 2011 | 09:09 AM
sfar785's Avatar
i dunno about the HX....the engine is the same, which means the head is the same so the exhaust studs on the head will mount up, the only problem that MIGHT occur is oilpan clearance, but if both motors have the same oilpan then you shouldn't have clearance issues.
Old Dec 13, 2011 | 12:57 PM
nytosc's Avatar
Hmm any more info?
thanks!
Old Dec 13, 2011 | 01:41 PM
civicjunkie17's Avatar
It should be fine. I have an hx, does the flange on the top of the downpipe that you have have 3 holes for studs? The only difference I could think of would being the cat itself because of the emission the hx was meant to put out. You should be fine.
SRd240sx
Oct 26, 2009 05:30 AM
racerx78
May 8, 2008 09:18 AM
monicle
Jun 21, 2004 05:25 AM
