ef b18b1 swap
hey every one i currently have an ef hatch with a b18 swap and am running a pr4 obd1 ecu i would like o know if any one here can tell me what year b18b1 ls engines are compatible with this ecu set up seeing as the engine that is in my car has recently died im trying to replace it but am unsure of what i can use with my current setup the current engine is a 94 but i want to know if any other years will work or not please if you have any insight on this please let me know thanks
pretty much any b series is going to work in your car aslong as you utilize your o2 sensor, ecu, dizzy and wiring and such
doesnt matter what obd the motor is
but to answer your question
92-93 da integras used the pr4
and 94-95 dc integras were also obd1 but used a different ecu, i think p72
Any '90-01 DOHC NON-VTEC B-Series will work fine. Just utilize all your OBD-1 stuff... it's really that simple. (Yes this includes both B18's and both B20's...) Obviously the B20 would preferably have the intake manifold swapped out and such - but you get the idea.
Do you need the whole swap or just the motor? I have shift linkage for the swap, and I kno some ones selling the whole swap, PM if your interested, I'm in PA semi close to philly
xwhitchx
Jul 10, 2009 11:33 AM
Propulsion
Jul 16, 2003 11:06 AM
88civicHB703
Apr 19, 2003 10:53 PM
