Name of part that locks the a/t shifter until brake is applied
Old Dec 12, 2011 | 03:28 PM
Blazinmiller's Avatar
Default Name of part that locks the a/t shifter until brake is applied
My 90 accord is having issues when cold with the part I described in the subject line. The end result is on a cold day, if I try to shut the car off before it warms up a good amount it will not let the key unlock the ignition.
I will put the car in park but the tranny gear indicator on the dash never fully goes in park until i hear an audiable "click" from around the shifter area.
When that part is acting up when cold, I can hear that same click every time I press the brake when it's in park.
It seems pretty obvious at this point that auto tranny locking mechinism is very sticky and unreliable when cold.
Old Dec 12, 2011 | 07:42 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Name of part that locks the a/t shifter until brake is applied
Here's a good read http://techauto.awardspace.com/ignit...tch.html#stuck
(35700-SM4-A91) SWITCH ASSY., AUTOMATIC TRANSAXLE GEAR POSITION and the solenoid is called (39550-SM4-A83) SOLENOID ASSY., AT (SHINDENGEN).
It could be that the (30158-700-010) E-CLIP (3MM) may have fallen off and the (54024-SD4-A40) PIN, SOLENOID may be cockeyed not allowing the solenoid to fully engage the switch.
Old Dec 14, 2011 | 10:20 AM
Thank you for the reply. One last thing, how do I translate the parts #'s you gave me to the schematic part #'s? Thanks again
marylandmx
Sep 30, 2011 07:13 PM
bowerskd
Oct 2, 2008 02:47 PM
standbackimapro
Jan 27, 2006 06:07 AM
bobobram
Aug 9, 2005 09:25 PM
bobobram
Aug 2, 2005 11:47 AM
