integra wont start
Old Dec 12, 2011 | 01:28 PM
accord6594's Avatar
Default integra wont start
car wont start after running fine yesturday. seems like the battery is dead bc it will click when you turn the key, but battery is good, terminals are right and clean, it just doesnt kick over. clutch switch is fine.after you take the key out you can hear a light clicking noise.
Car is a 97 integra, 5speed, LS model
Old Dec 12, 2011 | 03:00 PM
fcm's Avatar
fcm
Old Fart
Default Re: integra wont start
Check main grounds, batt. clamp and post, batt. to chassis and chassis to engine, do not just eyeball the connections, remove/clean/reconnect.
Also try a bypass jump... https://honda-tech.com/forums/showth...cm+bypass+jump 94
Old Dec 14, 2011 | 08:14 PM
Corollz's Avatar
If it just clicks when you go to crank it, and the batter is good, it is most likely a faulty starter
Old Dec 14, 2011 | 08:23 PM
DirtyDA9's Avatar
What they both said.
DC2GSR808
Jan 11, 2015 11:57 PM
Alcatrax30
Nov 23, 2014 08:46 PM
lamesa
Mar 19, 2014 10:11 AM
TheEricNielsen
Mar 20, 2013 06:57 PM
Hatchman98
Apr 23, 2007 03:20 PM
