Tach Dropped to Zero, then 91 Accord won't start
Old Dec 12, 2011 | 08:46 AM
Kyogie12's Avatar
Default Tach Dropped to Zero, then 91 Accord won't start
Alright so I have a 91 Accord with 215xxx on it. I pulled into work yesterday after it was driving just fine and the tach dropped to zero. BUT the car was still running and idling just fine...I shut it off and tried to start it up again but to no avail. I just replaced the spark plugs and wires 2k ago.
Anyone have this problem before? How can I test the distributor? Also i'm sure it could use a new fuel filter, but would that cause this? Thanks!
Old Dec 12, 2011 | 08:57 AM
Kyogie12's Avatar
Default Re: Tach Dropped to Zero, then 91 Accord won't start
Just to add the starter does crank, it just won't fire up.
Old Dec 12, 2011 | 09:05 AM
Aradin's Avatar
Premium Member
I've had it happen to me before, same symptoms. Plug popped out of the alternator, plugged it back in, jumped the car and it ran fine. Never popped out again.
Old Dec 12, 2011 | 09:37 AM
Kyogie12's Avatar
Huh. I'll check that. I unscrewed the banjo bolt a bit that goes into the fuel rail and turned the car on. Fuel came out so we're looking at a spark issue.
Took the distributor cap off, there was some white residue inside and a bit of oil on the outside bottom part of the cap. So i'm jumping it right now and seeing after a cleaning if that was it and if that's what i should replace!
Old Dec 14, 2011 | 02:51 PM
Lost Again's Avatar
Test the ICM and coil.......
jpozark56
Aug 12, 2015 03:52 PM
The Chairman
Feb 25, 2013 03:23 PM
Olias
Apr 10, 2012 04:45 AM
hdj20
May 27, 2010 10:21 AM
eathatch
Dec 7, 2007 08:14 PM
