97 civic ex pcv valve
anyone has any diy on how to changed a pcv valve? i seen some but im confused if you take it out from the top or you need to crawl underneath the car to take it out?
im having bad mpg but no cel.
any help its appreciated thanks everyone.
It plugs right into the black box thingy on the back of the block, below the intake manifold.
Almost impossible to remove from up top.
Have to remove the oil filter to have a decent shot at removing it, so your best bet is to change it at your next oil change.
Hope this helps!
Hope this helps!
Hope this helps!
Hope this helps!
if its original, there is a good chance it is stuck on there good and VERY VERY BRITTLE!!
spray some lubricating oil there and let it sit, then attempt to take it apart.
MugenMike
Feb 22, 2007 07:00 AM
MeanGreenEG9
Apr 2, 2002 06:53 PM
