Keep blowing instrument light fuse
Old Dec 11, 2011 | 08:26 PM
Cap'N Chronic's Avatar
Default Keep blowing instrument light fuse
Car is a 98 Civic EX with a OBD1 LS swap. Has a EM1 gauge cluster. I keep blowing the instrument light fuse under the dash. The recommended amp fuse is 7.5, but the 7.5 would blow as soon as I plugged it in, so I bumped it up to 10 amp. The 10 amp lasted for a while, but eventually blew out. Now as soon as I put in a 10 it blows. There was gauges of some sort and a alarm hacked into the harness that I had to remove. Any ideas on why I keep blowing the fuse?
Old Dec 11, 2011 | 10:38 PM
Default Re: Keep blowing instrument light fuse
I also have an aftermarket stereo installed, since this seems to be a common problem with people who have aftermarket stereos.
Old Dec 12, 2011 | 04:37 AM
grumblemarc's Avatar
The Grumpiest
Only if wires are hacked to hell. I have never had this issue in any car I have owned where I have installed an aftermarket radio. Sounds like you have too much hacked into that line. If you want to start a cabin fire just keep putting in bigger and bigger fuses until the wires melt.
Old Dec 12, 2011 | 05:59 AM
Which line are you talking about? And 10 amp is the biggest I'm going to put in it, thanks for the tip though haha
Old Dec 12, 2011 | 06:05 AM
The Grumpiest
Whatever line is blowing the fuse. I wouldn't even risk a 10amp.
Old Dec 12, 2011 | 06:38 AM
Wrona's Avatar
pull out your testlight or a multimeter and strart going to town resolder connections heatshrink them and wrap them you have a short somewhere
Old Dec 12, 2011 | 06:54 AM
How exactly do I test for a short?
jdmWONG
Honda CR-V & Element
Dec 31, 2011 01:52 PM
sleeperrex
Aug 24, 2008 04:12 PM
smallttocs
Acura TL, RL & ZDX
Oct 19, 2005 07:09 PM
makoe
Audio / Security / Video
Aug 16, 2004 04:11 PM
specv5150
Feb 23, 2004 05:26 AM
