Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
07 Civic Si clutch pedal spring replacement
Old Dec 11, 2011 | 01:51 PM
ITLNstallion818's Avatar
Default 07 Civic Si clutch pedal spring replacement
So my civic is plagued by the typical Honda clutch pedal "popping" and "creaking"... My clutch master cylinder has already been replaced by Honda. today I narrowed it down to the spring assist on the clutch pedal. There is a lot of play in the spring where it attaches to the assembly bushings, and that's the popping it makes when it rubs... I also noticed there was a broken plastic piece near where it attaches that just fell off when I touched it with a screw driver (I'm assuming it had something to do with stabilizing the spring), but I didn't see the rest of the plastic piece, so I'm not 100% sure what it did. What broke???
My question is, if I buy a new spring, are they easy to swap out? And what plastic piece should I order along with it? For those of you who are pretty familiar with the clutch pedal assembly on these civics... Thanks
Old Dec 11, 2011 | 02:13 PM
Default Re: 07 Civic Si clutch pedal spring replacement
and this is where i found that plastic piece circled in orange
Old Dec 12, 2011 | 06:55 AM
bee guz's Avatar
I had an issue with my toyota tacoma and to repair that plastic you needed to remove that bracket, put it in a vice and take it apart.
I would try to get a look at a honda service manual to see just what needs to be removed to get at it, to me it doesn't look like there is much to removing it.
AndyD
Sep 4, 2020 09:37 PM
devious
Jul 24, 2010 07:11 PM
808DA
Feb 5, 2009 10:34 AM
The Weather Man
Sep 19, 2005 06:29 PM
Paste
Aug 30, 2002 07:57 AM
