code 9 and smoking engine bay
today I finally got rid of my code 4 but code 9 stepped in and took over. I know it's the cylinder position sensor but I can't figure this @#!^ out, man!! I need some miracle advice to solve my probs. I know I should change the dizzy but that is my last choice. any tips would be great.
check ur timing
if your timing is okay
reset the ecu
see if code is still there
if so then check for loose connections and continuity
if still ok then replace dizzy
reset the ecu
PINKS
11
Jul 13, 2006 06:00 PM
