HELP !!! LSD OR NOT &!()#
please tell me if my itr gearbox LSD or not ( hopefully it is !! )
i jacked up the car , i span one wheel the other fucken wheel didnt spin !!!!
then i started up the car when the car still on the jack , and both wheels span by itself ??
my itr has ABS
and on the gearbox it says LSD , but its not like my crx , my crx when i jack it up and if i spin one wheel , the other wheel spins as well ( no abs )
help $*!_#@*!_)@
thanks
my itr has ABS
help $*!_#@*!_)@
thanks
I have an itr lsd. When I spin one tire the other spins also. I thought with lsd the tire was supposed to spin the opposite way, but I have never seen what happens when you do this to a FWD LSD car. I did this yesterday while hunting rattles.
With my gsr tranny both wheels spin very slowly when the engine is started and the tires are off the ground.
so mine isnt LSD ????
my crx gearbox if i spin one wheel , the other wheel spins to the opposite way
but my itr only 1 wheel spins, but when i start the engine and the front tyres off the ground, both wheels spin automatically , and its pretty fast too
[Modified by VTEC_SiR, 4:43 AM 10/8/2002]
no , i bought the car like that
i didnt installed anything
can u actually tell if it has lsd by looking the structure of the gearbox from outside ?
thanks
thanks
wtf are u talking about.. spanning? look if drive wheels are up in the air and both are spinning then thats a LSD, if only one wheel spins then its an open differential.
has nothing to do with abs...
[Modified by Muckman, 2:51 AM 10/8/2002]
you have an LSD man BUT it only works under POWER. Try and do this jack the car back up put it in gear THEN try and spin the tires
[Modified by hooptie157, 2:55 AM 10/8/2002]
if u spin 1 wheel the other wheel goes to the OPPOSITE direction , it can be because it has 1 way LSD , cant it ?
no, if the other wheel spin opposite direction, thats mean its open diff.
From the Helm manual: Jack up the front wheels, put the transmission in gear, spin one wheel, if the other wheel spins in opposite direction then the LSD is in working order.
This is for an ITR transmission
If your transmission doesn't do this then it is either defective or it is not equiped with an LSD
[Modified by JPP, 2:51 PM 10/8/2002]
