92 hatch z6 no heat question ?
Old Dec 10, 2011 | 07:37 PM
mini_eg_monster's Avatar
Icon2 92 hatch z6 no heat question ?
i got a 92 hatch with a z6 stock. I have heat in the car but not real hot .... What do i have to do to make the heat hotter ? or what do i have to replace ?
thanks.
Old Dec 10, 2011 | 07:48 PM
Former User's Avatar
Default Re: 92 hatch z6 no heat question ?
Does the engine warm up properly?
1 - Make sure the heater hose valve on the firewall is fully opened.
2- Check the coolant level in both the radiator and reservoir. If low, top off and bleed the cooling system.
Old Dec 10, 2011 | 08:11 PM
It takes a while for the thermostat gauge to get up to normal temp.
Old Dec 10, 2011 | 08:15 PM
You may need to replace the thermostat.
Old Dec 11, 2011 | 08:20 AM
o ok
Old Dec 12, 2011 | 05:40 PM
Kohen's Avatar
so with a perfectly fine thermostat the temperature gauge goes straight to normal operating temperature? or even with a perfectly fine thermostat does it take a little while?
Old Dec 12, 2011 | 06:28 PM
It will take a little longer to get to operating temp when it's very cold outside. In general, I think the engine should reach operating temp in less than 5 min of driving. With a stuck open thermostat, it will take much longer or will never reach operating temp.
Old Dec 12, 2011 | 06:38 PM
Kohen's Avatar
okay. good to know.
Old Dec 12, 2011 | 07:55 PM
DCSportEJ1Civic's Avatar
possibly flush the heater core and/or cooling system.
Old Dec 13, 2011 | 01:44 PM
I checked it out today and when ive been driving for longer than 10 minutes with the heat off the temp gauge goes to normal. Then when its at normal op temp i turn the heat on and the temp gauge goes all the way to cold?
Old Dec 13, 2011 | 01:56 PM
nmellenthin's Avatar
myne did this right after i bought it. the thermostat was stuck open. also when i was on the interstate it would not warm up. too much cold air. replace the thermostat. its a cheap and easy thing to do. its like 3 bolts
pigskinrodeo
May 15, 2013 10:19 PM
swindian1991
May 1, 2013 02:33 PM
escowop
25
Sep 6, 2010 05:29 PM
sirtef9
Feb 15, 2010 07:23 PM
Akalima
Nov 27, 2007 03:30 PM
