Which lower tie bar will fit under ITR sway bar in a EG hatch? *PIC*
Old Oct 7, 2002 | 06:20 PM
DB8's Avatar
DB8
Default Which lower tie bar will fit under ITR sway bar in a EG hatch? *PIC*
anybody know about it? i am using ITR rear lower control arm, ITR sway bar with beaks bracket.............
let me know if you guys know what will fit under there???????
Thanks in advance
Old Oct 7, 2002 | 06:36 PM
hatchdrvr's Avatar
Default Re: Which lower tie bar will fit under ITR sway bar in a EG hatch? *PIC* (DB8)
I have the same set up for my car, I am also wondering because i am looking into the Cusco lower tie bars fronat and rear.
Old Oct 7, 2002 | 06:41 PM
stevecockrill's Avatar
Default Re: Which lower tie bar will fit under ITR sway bar in a EG hatch? *PIC* (ForceFedEG)
I think that many will fit if you use longer LCA pivot bolts and a couple of standoffs - I have a Neuspeed on mine.....
Old Oct 7, 2002 | 06:43 PM
JV's Avatar
JV
Who?
Default Re: Which lower tie bar will fit under ITR sway bar in a EG hatch? *PIC* (stevecockrill)
http://www.beaksproducts.com/upgrade.html
Old Oct 7, 2002 | 06:46 PM
eg6sir-s's Avatar
use the jic-magic rear tie bar...it works with the itr rear sway on the eg's as well as dc2's
Old Oct 7, 2002 | 06:48 PM
DB8's Avatar
DB8
from this pic, it kinda look like it's hitting it? no?
and as for the JIC rear lower tie bar, how does it look like? never seen it before
what about the skunk2? spoon?
Thanks
Old Oct 7, 2002 | 06:58 PM
eg_nezay's Avatar
Thanks in advance
looks like your pipping will be on the way for a tie bar correct me if Im wrong
Old Oct 7, 2002 | 08:36 PM
FutureFrank's Avatar
Default Re: Which lower tie bar will fit under ITR sway bar in a EG hatch? *PIC* (eg_nezay)
I HAVE AN ITR SWAY BAR AND NEED A BEAKS KIT WHERE DID YOU FIND IT 4
Old Oct 7, 2002 | 08:41 PM
fowler!'s Avatar
Default Re: Which lower tie bar will fit under ITR sway bar in a EG hatch? *PIC* (FutureFrank)
WWW.BEAKSPRODUCTS.COM!!!!!!
Old Oct 8, 2002 | 03:29 AM
No it doesn't hit. Once you use the standoffs, it clears the sway bar mounting hardware.
Very easy. I think Beaks has a combo package that includes the appropriate hardware......check his site.
Steve
Old Oct 8, 2002 | 07:30 AM
kefka's Avatar
i just grinded some of my bracket off and relocated the bar up an 1/2in...
TSAngry
Oct 11, 2003 02:34 PM
B18C1_EK
Feb 28, 2002 12:01 PM
BlueG3Teg
Feb 18, 2002 04:52 PM
