? on corner lights need help
Old Dec 10, 2011 | 10:46 AM
rudyndrew's Avatar
Default ? on corner lights need help
Well 1st off they work fine but I just want the bumper lamps to be on with corner lamps at the same timehow or which ones would I have to tap into? My crx was like this but I want it this way for my 91 hatch
Old Dec 10, 2011 | 11:10 AM
accordin 2 me's Avatar
Default Re: ? on corner lights need help
volt meter/ test light black wires are ground. come on man, TRY
Old Dec 10, 2011 | 01:45 PM
91efbluehatch's Avatar
wow...that was alot of useful info.
OP here is what i did. look on your corner lights.
see which wire is the + and which one is the ground. i cannot remember correctly, but if i have to, i will go out to my car and check.
once you find which one is the + it should just be a matter of tapping that wire into the positive on the blinker. and you SHOULD (dont quote me on this 100%)
have your bumper lights act as your running lights, since your blinkers are on a different circuit and they are a dual element bulb
Old Dec 10, 2011 | 02:08 PM
lazlong's Avatar
You'll need to tap that wire AND cut and cap the wire going to the bumper light so the only feed is the corner light wire.
Old Dec 10, 2011 | 02:38 PM
KINGVEM^^ED6's Avatar
iv been thinking of doing this too
why not just tap into the outter socket wiring on the corner light?
idk if it will work but its worth a shot
Old Dec 10, 2011 | 07:48 PM
If you have to tell someone which wires to go to on something as simple as corner lights and bumper lights i dont feel like you should even attempt it. It just looks like your lazy and its nothing five minutes with a volt meter wouldnt find out.
Old Dec 10, 2011 | 11:46 PM
tonylovesjdmEF9's Avatar
GHETTO
toolbox21
Jun 16, 2009 08:18 PM
asianalbutt
Nov 17, 2005 06:29 PM
accord0494
Jul 29, 2005 09:02 PM
rjr162
Audio / Security / Video
Feb 14, 2005 05:56 PM
