welding spoiler holes?
i've got my DC4 with holes in the hatch
one of the previous owners put a type R replica wing on it with a 3rd brake light
i dont like it so i want to remove it, but without a stock LS wing i'd rather just go without one
how much should it cost to get it welded up at a shop? if i have it all stripped down and just bring my car in?
i'm looking for them to just weld it, they dont have to paint it or anything
i would weld it myself, but i dont have a welder (anyone suggest a budget MIG welder?) and my garage isn't wired for one yet
I wouldn't think any more than $50. Its pretty simple to do, you just have to keep the heat down to not warp the panel.
I would get a small miller mig welder. I have a little miller 90 that I bought along time ago for 150$, we use it all the time.
Most little mig machines are 115v, so you can just plug it into a normal house outlet or run it off an extension cord.
i took a class on automotive welding a couple semesters ago, but i couldn't really seem to get the hang of welding on thin metal. I would burn through it a lot of times when welding from bottom to top, but not so much when going top to bottom
think i should still try and give it a go?
I've done this on two of my hatches, cut a thin gauge piece of metal out that fills up the hole, then just pull the trigger on the welder real quick (almost like a spot weld) and just keep doing that around the whole hole. after a couple zaps put a wet rag on it to cool it off then continue.
and by decent sized do you mean wide? or just thick enough to suck up the heat?
mr darcko
14
Feb 11, 2015 10:32 PM
comptechgsr
Jul 15, 2001 08:52 PM
