Bleeding Question
Old Dec 9, 2011 | 03:50 PM
motegicivic's Avatar
Default Bleeding Question
96 Civic EX
I attempted to bleed my cooling system about 1 month ago, I get random running hot at idle ( happens like once a month) and think there is air in the system.
My fan does come on.
First attempt to bleed I do not think worked because of the random running hot and I can hear gurgling in the heater core in the dash.
Should I do it again, anyone have this problem getting the air out, any tips?
I have followed the proper bleed procedure as posted on here.
Old Dec 9, 2011 | 04:20 PM
lazlong's Avatar
Default Re: Bleeding Question
Just bleed it longer- as long as it takes.
Old Dec 10, 2011 | 11:02 AM
Ok, just bleed again.
The thermostat did open and saw flowing coolant.
The fan came on twice.
I did notice bubbles, is that air?
Also, as it ran coolant was steaming a little (was about 45 degrees out), is that normal?
Old Dec 10, 2011 | 11:16 AM
EsotericImage's Avatar
Retired Moderator
ok, try and put the car uphill.. use ramps, jack, whatever
start car with cap off
turn on the heat full blast
rev engine a little to get water moving..
when the level goes down, fill it up, keep doing this till no more bubbles come to the surface.
Old Dec 10, 2011 | 11:52 AM
Former User's Avatar
Do you see a continuous stream of bubbles in the coolant? If so, could be a head gasket problem that is allowing exhaust gases in the cooling system.
Old Dec 10, 2011 | 03:14 PM
Hard to explain, sort of random bubbles it seems like. I also checked the overfill no bubbles in there.
I did a block test like 2 months ago, came out ok.
I assume some bubbles is normal air still in there?
Old Dec 10, 2011 | 03:16 PM
There should be no gas bubbles in the cooling system.
Old Dec 10, 2011 | 11:13 PM
Most videos I saw online when someone was bleeding the system has some sort of bubbling.
What does air look like when it is the system if it is not bubbles?
Old Dec 11, 2011 | 03:11 AM
Retired Moderator
What Ron is saying is
"if the bubbles continue to be coming up and dont stop, you have a headgasket issue."
If you followed my advice up there, and done it correctly, you should see no bubbles.
Old Dec 11, 2011 | 08:15 AM
I did not have a chance to get the front up, but I do not really hear the gurgling in the heater core anymore.
There might be a little air in there and I am impatient and do not want to do it more than 1/2 hour, or possibly a head gasket issue.
I am wondering I have had a random ( like once a month) run hot at idle for 6 months or so, replaced fan switch got better.
If the headgasket was bad, wouldn't after 6 months it would go by now?
Old Dec 11, 2011 | 08:23 AM
grumblemarc's Avatar
The Grumpiest
Then what do you want people to tell you?
If there are bubbles because of a failed head gasket then it has already "gone". I don't know what you're expecting.
Old Dec 12, 2011 | 03:41 PM
Took it in to the dealer.
Block test, came out ok........so I guess a some bubbles does not mean failed head gasket.
Pressure test came out ok, no leaks.
They could not make it run hot again, which does not surprise me.
To play it safe I had the thermostat changed, I will watch it for now on to see if it will run hot at idle.
mlee19841
Honda Civic (2001 - 2005)
May 1, 2015 03:26 PM
sickofitall1113
Feb 12, 2011 08:11 AM
732xghost
Aug 23, 2009 08:48 PM
crxricer66
Dec 10, 2007 04:41 AM
sony224422
Feb 27, 2006 09:13 AM
