1992 Accord clutch issues...
Random times my clutch sticks to the floor and i have to lift it back up with my foot (springs back w/ a little lift) or pump it.. lately it has been doin it alot and im losing clutch fluid frequently... hose and what not looks good..someone told me it could be the master cylinder. Anything at this point helps. Thanks!
Look under your clutch pedal, the master cylinder is behind that, look for any leaking. Look by the slave cylinder, which pushes the actual clutch on the transmission. Check if your clutch fluid level went down, or if it is low.
