2000 Lude PM, vtec, dizzy o-ring
Old Dec 9, 2011 | 08:32 AM
Velocity1's Avatar
Icon2 2000 Lude PM, vtec, dizzy o-ring
Guys,
In preparation for my ultimate dyno tune, my Tuner recommended I replace the vtec gasket/o-ring set, distributor o-ring and cam plug(s) as they look like they're beginning to weep. No wet spots at 115k miles, just weeping. I'm also going to have the valve lash checked and adjusted as required and will install a new Honda v-cover gasket set.
I have the Factory Service Manual for the car. I'm a wrench in my own right, (Aviation mechanic).
My questions are, what am I up against? I've had the distributor out before. Cake.
Vtec solenoid removal doesn't look too difficult and the mechanic doing the valve lash will do the cover gasket re-install.
Cam Plugs? What's the best way to remove and replace them?
I'm trying to cut down on some of the expense of time and materials prior going to the dyno.
Where can I get the best prices on the parts I need? And can anyone give me any tips that might be helpful during this preventative maintenance?
Thanks, V1
Old Dec 9, 2011 | 09:48 AM
igotthaspirit's Avatar
Default Re: 2000 Lude PM, vtec, dizzy o-ring
If they arent leaking dont waste your time. Just hang on to the parts in case they start leaking. All of those parts are super easy to change out. Just read your manual
Old Dec 9, 2011 | 12:13 PM
Velocity1's Avatar
Yeah. Kind of what I was thinking. Tuner is a little overly precautious, plus it puts ching in his pocket when I can do it for 30% of his cost.
May just clean surrounding area with 2+2 make it all look nice and clean and send it in for the dyno.
I've got the first task of installing the header, cat and 2.5 pipe to the muffler though prior to OBDI tuning on the dyno. I'm going to custom mount the OBDI on the tray next to the OBDII so it's all plug and play when smog test time comes around. I'm plugging the OBDII back in tonight until I can have the OBDI base map tuned, probably right after the holidays.
Old Dec 9, 2011 | 12:22 PM
Velocity1's Avatar
Where is a good source of Honda parts that offer good prices to the forum members? I have to order the valve cover set. Might as well get the others and put them on the side for when I need them.
Thanks, V1
Old Dec 9, 2011 | 03:00 PM
I use hondapartscheap.com but shipping kills. You might call your local dealer. All those parts are maintenance items and should be in stock.
Old Dec 9, 2011 | 03:56 PM
Velocity1's Avatar
Thanks for the shipping cost(s) heads-up..You're right. Might be smarter to shop for these items in the neighborhood..
Thanks,
V1
Old Dec 9, 2011 | 04:59 PM
InvaderTrax's Avatar
Cam plug is very easy. You can either pop it out and massage the new one in, or remove the valve cover gasket, then the four bolts that hold the cam cap on and R&R the plug
Vague
11
Jan 2, 2016 08:21 AM
djkurious
Mar 3, 2014 07:01 AM
Keevin77
Nov 26, 2012 09:54 AM
fortillian
Feb 18, 2011 11:07 AM
H2290
Jul 22, 2006 06:48 PM
