vacuum leak?? 91 EF hatch
Old Dec 8, 2011 | 06:51 PM
LowAndSlowEF's Avatar
Default PLEASE HELP!
hey whats up, i have a 91 hatch, with a sohc ZC swap...buuuuuuut i had to leave it DPFI for a while (lost job, and no ecu) so anyways it is running really rough like maybe it has a vacuum leak somewhere??? i just wanted to get some feedback...im NOT throwing any CEL btw. i replaced the spark plugs, spark plug wires, both battery wires,intake manifold gasket and alternator....its reving about 1500 to 2200 rpms.. it would jump on its own..then it will just die....also when i try to rev it up, it will have poor throttle response. please let me know what you think
Old Dec 8, 2011 | 09:39 PM
Default Re: vacuum leak?? 91 EF hatch
anyone???
Old Dec 9, 2011 | 05:11 AM
crvtectim's Avatar
Sounds like you may need to clean your FITV if it's loping up and down from 1500-2200 rpms. Here: https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-fix-fitv-its-easy-1-2-3-a-699787/
Read up!
Old Dec 9, 2011 | 01:36 PM
im still DPFI , and i know that these dont have one, :/
Old Dec 9, 2011 | 09:44 PM
acmoc's Avatar
try seafoaming your car.
Did it for me
Old Dec 10, 2011 | 01:32 AM
ok thank you. ill give that a try...anyone else want to give some input?
Old Dec 10, 2011 | 08:29 AM
acmoc's Avatar
try your ignition timing at the distributor. three 12mm bolts
slide it towards the firewall to retard and towards the front of the car to advance
replace all your vacuum hoses, 15 bucks max
the seafoam will help a lot and pinpoint the problem
Old Dec 10, 2011 | 08:31 AM
acmoc's Avatar
also makes sure your idle is well adjusted. throttle cable should have good amount of play
the sticker under your hood will say where it's supose to be. and if its not too much. Do a valve job
Old Dec 10, 2011 | 01:05 PM
thanks a lot! im going to look it over and test for the leak ...i already adjusted the timing, but ill look into that also.
Old Dec 10, 2011 | 04:30 PM
jpciii's Avatar
vacuum leak is certainly a possibility.
I've experienced a couple other causes of the symptoms you describe:
idle air control valve - clean it out and make sure there is no air in the cooling system... which may require repeated drives to work out all the bubbles.
distributor - try a known good one.
Old Dec 11, 2011 | 03:34 AM
i got it to stay on, running a lot better than before...it was a vacuum leak. it still revs up and down a little ...but i have to charge my battery and check for more leaks tomorrow ...ill keep you updated
Old Dec 11, 2011 | 03:36 AM
my distributor is brand new btw....i need to get all the air out of my cooling system also
Old Dec 11, 2011 | 10:39 PM
i have a clogged catalytic converter.... lol i drove it around and let it sit for a while...and looked at the cat...(glowing red and smoking slightly)...and i know its not running rich from spark because it was all replaced (distributor,wires,and plugs)..thank you all who have helped by responded back....ill keep you updated
jdm91ef
Jun 4, 2013 04:01 PM
d3r3k92
Feb 27, 2012 11:15 AM
KRZRICAN
11
May 20, 2010 02:17 PM
jons91ef
Dec 11, 2007 02:03 PM
