I'm an idiot - Fuel gauge question
Old Dec 8, 2011 | 01:54 PM
HooniverseJeff's Avatar
Default I'm an idiot - Fuel gauge question
So, I was removing the stupid gauge faces installed by the previous owner. Thankfully, the original gauges were sitting just underneath.
When getting the crap ones off, I snapped the fuel needle off (ARGH!)...
Question, am I boned or is there an easy fix here?
Previous gauges, just because:
Old Dec 8, 2011 | 02:09 PM
98civdx's Avatar
Master Detailer
Default Re: I'm an idiot - Fuel gauge question
Replace the fuel/temp guage.
you buy them new at Honda.
Old Dec 8, 2011 | 02:42 PM
94EG8's Avatar
Seagull Management
Sometime super glue works, put a drop of glue on the pin get it back in the right spot and keep turning it so the glue doesn't glue it the shaft turns in.
Old Dec 8, 2011 | 02:43 PM
I may give that one a shot, thanks!
Old Dec 9, 2011 | 07:01 AM
zerovandez's Avatar
The needle on my temp side broke. I just replaced that whole side. It was like 30-40 bucks I think.
Old Dec 9, 2011 | 07:48 AM
Cool, thanks for the insight...
I now have another question though.
When removing the **** gauges that were covering up the original gauges, I cut away wiring that allowed you to change the brightness of the aftermarket units. In doing so, I must've cut the actual wiring to the real gauges - they don't light up anymore.
Is this an easy fix?
Old Dec 9, 2011 | 03:56 PM
motegicivic's Avatar
Don't those needles just pull off the stem? I bet you can get a new needle, say ebay, junk yard.
Old Dec 9, 2011 | 05:21 PM
98civdx's Avatar
Master Detailer
They do, just pull right off. BUT, they aren't that easy to pull off, and break. Often times when they break it's not the needle, it's the actual guage.
I've never seen the needle break, always the thing the needle sits on.
Canucksfan101
May 7, 2014 09:48 PM
Luke G.
Oct 30, 2009 12:04 PM
801ef
Jun 3, 2008 07:14 AM
jpnucrx
May 13, 2006 10:58 AM
pleekh73
Jul 3, 2005 09:37 AM
