Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Header Question
Old Dec 8, 2011 | 01:50 PM
Kentagious's Avatar
Default Header Question
So I have an 07' Si with a DC Sport race header, AEM CIA and Hondata Reflash Pro. for some reason over the last 6 months is sounds like I have a exhaust leak. I thought the bolts that connect the exhaust and the header together might be loose, but after jacking the car up I found that they are tight. My only other though is that there is this mesh tube that is part of the header that it might be leaking from. here is a pic of it:
Any one have this issue too?
Thanks for any help.
Old Dec 9, 2011 | 06:56 AM
bee guz's Avatar
Default Re: Header Question
That mesh tube is a pain, I have seen that fail on other cars, what you might try doing is eliminate it, but the way it looks in your pic is going to be a big job.
It is designed to allow engine movement so it won't vibrate thru the exhaust system.
Have you tried wrapping it maybe some header wrap will help.
Old Dec 11, 2011 | 12:03 PM
spdrmn's Avatar
i had a similar problem. when it took the cat back off the gasket crumbled to pieces. it looked fine from just lookin at it but when i unbolted the catback from the header/downpipe/testpipe (whatever you wanna call it) the gasket just fell to pieces. after replacing the gasket i didnt have the issue any more. may wanna check that. its a way easier fix.
Old Dec 11, 2011 | 06:29 PM
arlo03's Avatar
Dc's are notorious for leaking at the flex pipe. Skunk2 FTW.
Old Dec 12, 2011 | 12:16 AM
Kentagious's Avatar
Good Idea on the gasket, I'll try that first.
Thanks.
Old Dec 12, 2011 | 11:01 AM
spdrmn's Avatar
another thing u can try too.....spray a lil soapy water on the flex pipe with the car runnin and look for bubbles.
SlowSOHC-T
14
Oct 21, 2008 04:43 AM
dballard
Oct 25, 2007 05:01 PM
midwestR
Aug 18, 2006 08:27 AM
robbieshonda
Mar 4, 2003 04:33 PM
prelude10
Jan 24, 2002 02:56 AM
