ex b16a2 swap - codes 14, 54, and 70
Old Dec 8, 2011 | 09:24 AM
wolf95's Avatar
Default ex b16a2 swap - codes 14, 54, and 70
Hey guys. I just installed a 99 b16a2 into a friend's 98 civic ex coupe. I used the ex harness but I had to unused plugs. One was by the fuel injector wires which I figured out was for the emissions thing bolted to the fuel rail. Now I have a three wire plug hanging right above the oil filter.
Now I check the CEL and of course it threw the Crank angle sensor no input code. Naturally, Nothing was plugged into it. Now am I supposed to extend two wires from the three wire plug for the two wire CKF? if so, which colored ones? We're using the ecu that came with the swap and I doubt he'd want to do the whole OBD2-0bd1 harness with a p28...
Also, I took it for a spin and if I was easy on it, it accelerated with no problem. If I mashed it, it bogged down and didn't want to move. I was thinking map sensor but could this fix that too?
I know there's also a bypass trick but that's if nothing else will work.
Thanks.
Old Dec 8, 2011 | 12:25 PM
wolf95's Avatar
Default Re: ex b16a2 swap crank angle sensor
buump
Old Dec 8, 2011 | 01:42 PM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-depin-2-wire-ckf-3-wire-2876493/
Former User's Avatar
Crank angle and fluctuation sensors are different. What specific codes are thrown?
Old Dec 8, 2011 | 02:44 PM
wolf95's Avatar
I was in a hurry so I didn't get the exact number for the code but I got the code for Crank position sensor no input.
and Hondapartshero, so that IS the right plug?
Old Dec 8, 2011 | 03:32 PM
CKP is code 4.
Old Dec 8, 2011 | 04:07 PM
wolf95's Avatar
Originally Posted by RonJ@HT
CKP is code 4.
well I wont have the OBD2 tester until I fix this and see if it goes away.
Old Dec 8, 2011 | 07:26 PM
wolf95's Avatar
bump
Old Dec 8, 2011 | 07:29 PM
Without knowing the actual code, it's just guesswork. Jump the service connector to pull the code ---> see CEL sticky at the top.
Old Dec 9, 2011 | 01:30 AM
Technical Hero
Yeah the CKF (by the crank) and CPS (in the distributor) are two different things. Pull the code and post.
Old Dec 9, 2011 | 06:33 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
http://ff-squad.com/technet/ckftrick.htm
as said, post the code.
Old Dec 9, 2011 | 07:40 AM
wolf95's Avatar
its showing codes
14- IACV
54- crank fluctuation sensor
70- ??
Old Dec 9, 2011 | 07:50 AM
Technical Hero
Theres no reason to bypass it if it's already there. Just repin it
Old Dec 9, 2011 | 08:38 AM
wolf95's Avatar
Well now I'm confused. do I need to wire up the one behind the crank pulley or is it something that needs done to the distributor??
Old Dec 9, 2011 | 08:59 AM
Code 70 is an automatic transmission malfunction code. What ECU do you have?
Reset the ECU to see whether all three codes repeat. The ECU reset is done by removing the 7.5A hood Back Up fuse for at least 3 minutes.
Old Dec 9, 2011 | 09:30 AM
wolf95's Avatar
P2E ECU
Old Dec 9, 2011 | 09:38 AM
Originally Posted by wolf95
P2E ECU
Is this^ ECU for an automatic transmission? Does your buddy have an automatic transmission linked to his B16a2?
Did you reset the ECU? If so, what happened?
Old Dec 9, 2011 | 09:44 AM
wolf95's Avatar
i pulled the negative cable off the batter AND the back up fuse and all three came back
Old Dec 9, 2011 | 09:45 AM
wolf95's Avatar
He ordered this full swap from ebay so I'm not sure about if the ECU is for an auto. No, it's definitely a manual transmission and so was his old D16y8.
Old Dec 9, 2011 | 09:48 AM
wolf95's Avatar
wait, I just checked an ecu list and this came up:
P2E OBD2 no VTEC 1996-1998 Honda Civic DX
did he get the wrong ecu??
Old Dec 9, 2011 | 09:50 AM
wolf95's Avatar
P2T OBD2b VTEC yes 1999-2000 Honda Civic Si
I believe this one's the one it's supposed to be
Old Dec 9, 2011 | 10:19 AM
Yes, wrong ECU for the swap. That's the cause of code 14 and 70.
When he gets the right ECU, he'll also need an OBD2a-OBD2b conversion harness.
Code 54 may just be a wire problem or the CKF is unplugged. You need to remove the crank pulley to check it.
Old Dec 9, 2011 | 11:18 AM
2fastek's Avatar
get a jumper and run a obd1 computer, problem solved.
Old Dec 9, 2011 | 03:32 PM
wolf95's Avatar
That was my other question, I couldn't find a plug to run to the cfk.
And so either way I have to run a conversion harness??
Old Dec 9, 2011 | 03:44 PM
wolf95's Avatar
I wouldn't have to run a different dizzy or injectors for the chipped OBD1 ecu? I've never had to use a conversion harness before.
why are EK's so damn annoying.... I wanna get back to my del Sol.... >_<
