GSR Throttle cable on ITR?
Ok so im going to swap my new itr swap in my integra ..i have my previously gsr throttle cable still can i use that on the itr or will it be too long? Or can i use b16 throttle cable that i have spare laying around ? Thanks !
Ok nevermind.. im going to end up buying the ITR throttle cable ..i called up import shop here in twn & told me either can be used that i need the ITR cable for it..
why would you need an itr cable when the b16 is almost the same? sounds like that shop is just trying to sell you something.
try both cables you have and if neither fits then buy an itr cable.
Well I asked if they sold ITR throttle cable there when he told me I can't use neither & he told me no that I would have to buy at acura dealership.
For easy installation using an ITR tb cable/bracket will be the easiest option.
If you decide to go with the GSR cable then you will have to modify a bracket to hold it in place.
Bump
I am swapping a 96gsr motor into my 95ls shell. Ur saying if I don't want to buy a throttle cable I can just swap my ls throttle body onto my gsr IM?
Ive heard people using ls cables on gsr swaps and having no problems (since they are longer and u can just tighten it)
Bump
s10cky
Nov 25, 2006 10:26 AM
jaystation
Aug 5, 2005 06:08 PM
