Fs- Ft/ 2009 Yamaha Raptor 700 R Sport Atv
Edit------- CHAIN AND REAR BRAKES ARE NOW BRAND NEW I PURCHASED AND REPLACED....
Please read carefully I am still paying it and it needs minor things a chain rear brake pads one front tire and throttle lever housing. Thing just sits havent rode for over a year.
Looking for another car to drive while i can complete my cars odds and ends. any questions please pm me
ill also sell with a bill of sale or notarized paper work. or both. ill continue payments you take it clean and clear. since im still paying i do not have a title but ill prove that its under my name and ill show a billing statement.
I will continue payment on it i am very **** about my credit.
Type
686cc liquid-cooled w/fan, 4-stroke; SOHC, 4 valves
Bore x Stroke
102.0mm x 84.0mm
Compression Ratio
9.2:1
Fuel Delivery
Yamaha Fuel Injection (YFI) , 44mm
Ignition
16-Bit ECU
Starting System
Electric
Transmission
5-speed w/reverse; wet multiplate clutch
Drive Train
2WD; sealed O-ring chain, eccentric adjustment
CHASSIS
Suspension / Front
Independent double wishbone w/piggy back High-/Lo-speed compression, rebound and threaded preload adjustment, 9.1-in travel
Suspension / Rear
Cast aluminum swing arm w/rebound, High-/Lo-speed compression and threaded preload adjustment, 10.1-in travel
Brakes / Front
Dual ventilated hydraulic disc, twin piston
Brakes / Rear
Ventilated hydraulic disc, self adjusting park brake function
Tires / Front
AT21 x 7-10 radial
Tires / Rear
AT20 x 10-9 radial
DIMENSIONS
L x W x H
72.6 x 46.1 x 44.5 in
Seat Height
32.0 in
Wheelbase
50.4 in
Ground Clearance
4.4 in
Fuel Capacity
2.9 gal
Wet Weight
422 lb
OTHER
Lighting
Dual 30W Krypton multireflector headlights & 3.9/0.5W LED brakelight
Type
Bore x Stroke
102.0mm x 84.0mm
Compression Ratio
9.2:1
Fuel Delivery
Ignition
16-Bit ECU
Starting System
Electric
Transmission
Drive Train
CHASSIS
Suspension / Front
Suspension / Rear
Brakes / Front
Brakes / Rear
Tires / Front
AT21 x 7-10 radial
Tires / Rear
AT20 x 10-9 radial
DIMENSIONS
L x W x H
Seat Height
32.0 in
Wheelbase
50.4 in
Ground Clearance
4.4 in
Fuel Capacity
2.9 gal
Wet Weight
422 lb
OTHER
Lighting
ill wash her up this weekend and take better pics...
she also has full gytr under skid plates front a arms to swing arm and gytr shock covers stock besides that.
fmrprojects
Northern California (Sales)
14
Feb 15, 2006 11:16 AM
