95 Accord feels slugish before 2500 rpms
Old Dec 6, 2011 | 09:53 PM
integra_661's Avatar
Default 95 Accord feels slugish before 2500 rpms
Ok so I want to get some thoughts on this before I send it to the mechanic. I have a 1995 Accord 5 speed that I just recently changed out the fuel filter and transmission oil and after Idid this to the car it started to run sluggish below 2500rpm but after it passes those rpms it runs normal. I triple checked all hoses as well. does any have any thoughts on this or what I can try to do, any thoughts would be helpful. Thanks in advance!
Old Dec 6, 2011 | 10:10 PM
ed124's Avatar
Default Re: 95 Accord feels slugish before 2500 rpms
When u switched ur oil, is it synthetic or non-synthetic? When i swtiched from non-s to synthetic, my idle become more quieter. Iono if that helps.
Old Dec 7, 2011 | 05:24 PM
roncourville's Avatar
use synthetic 5w-30
Old Dec 7, 2011 | 09:40 PM
Thanks guys but Ive been using synthetic for years now and always ran well, its gotta be something else cuz it really has no power before 2500rpms I can be flooring it and its going no where. Ill try and get some video to give you guys more of an idea
Old Dec 7, 2011 | 11:49 PM
MAD_MIKE's Avatar
MM Gruppe B
Are you sure you did not knock anything loose? Are you positive that the fuel filter was installed the correct way? Turn the car to ON and check for fuel leakage.
Old Dec 8, 2011 | 12:56 AM
holmesnmanny's Avatar
Yeah, those fittings have to be on tight or they will leak and the location of your model's fuel filter is really a bad spot. You could have knocked anything loose or had something undone still.
stackz
Jan 17, 2016 09:00 AM
Ntense_Civic
Apr 20, 2012 04:47 PM
Bear Down
Nov 21, 2005 08:16 PM
01YellowITR
Feb 5, 2002 10:21 PM
Chris93Si
Jan 1, 2002 01:31 PM
