COUPEDUP -- 93' EJ1 #0069 -- I miss summer...
Been around since 01'-02', joined in 03'
I don't post as much as I used to when H-T was all tech/no BS
To start...
I am a certified Acura mechanic and have done all work myself in my garage or at work. Been working on Honda's/Acura's for almost 10 years and started when I was 17 working on motor swaps and custom turbo kits in the earlier 00's.
Never finished my first H22a CB7 Accord project back in 2003 before moving west for work in 2006.
After owning beaters and my 05' Suzuki GSXR 750. I wanted another built Honda. Always loved Coupe's.
On to the good stuff.
I am skipping over all the old build pix, but I will share some brief details and things were changed over quickly.
General info:
After almost a year of searching and waiting -- Purchased in October 2009. ALL STOCK 280,000km's but MINT body condition for $2600
-1993 Civic Si R81 #0069 haha =cP
Slowly but surely..... Back in 09'
-GSR Rear disc conversion
-ITR front/rear sway bars
-Tokico Illumina's with Neuspeed Race Springs
...then Summer 2010:
-94' model JDM GSR swap
-15" x 6.5" +45 Racing Sparco NS-II's on 195/50R15 Bridgestone Potenza RE-11's.
Currently looking like this:
Pix from over the summer.. this was posted in the Ej1 group thread aswell. Never bothered to throw it in the general mix. Copy-PASTE BAM!
^^ yea. that's me looking like a dork in the Rage shirt. =cZ
finally the reason why I built her... lapping days
^^ picture taken exactly 1 week after I swapped the B18c back in after I rebuilt and upgraded it over winter. banging 9000rpm no problem.
she also gets dragged around...
Currently:
-Black/Red-stitch Recaro's
-DB8 ITR black/red stitch rear seat covers custom fit on EJ1 Rear cushions
-Accessory arm rest with custom ITR lid
-CTR 5-piece carpet set
-My oldschool 1994 model Momo MonteCarlo steering wheel.
-SiR-S Cluster
-ITR shift boot
-ITR shifter w/skunk2 ****
-Honda Access rain deflectors
-Kenwood deck
-CTR 32mm 5-lug swap
-Power-slot rotors all around
-MINT 16" Gunmetal ITR wheels on 205/45R16 Bridgestone Potenza RE-11's
-6mm spacers in the rear
-Earl's stainless brake lines
suspension is unchanged except for an ASR brace and Spoon Front/Rear Strut bars
specs on the motor:
JDM B18c GSR block
new Honda bearings, rings, seals
ARP Main Studs
ARP Rod bolts
ARP Headstuds
PR3 pistons (bumps up c/r to about 11:1)
Honda CTR crank pulley
Honda Headgasket
JDM B18c GSR Head
ITR cams
1mm oversized intake valves
new valve guides and seals
mild porting/smoothing to match the oversized valves
Hondata I/m gasket
Skunk2 version 1 intake manifold
stock TB
Custom 3" 304 Stainless intake (made by me)
K&N filter
Spoon plug-wires
Spoon Oil cap (Mugen cap is pictured)
Vision Technica 4-1 Header
2.5" test-pipe
2.5" T1R mid-pipe
Fujitsubo Giken Legalis R muffler
Koyo Aluminum rad, ARC and Spoon Caps
Samco Hoses
Carbing catch-can for PCV and valvecover vent
Stock USDM ITR 4.4FD Trans
Competition Clutch 2300
Competition Clutch ST Flywheel
Crome Tuned to 9200rpm
Over this winter rebuild:
-Body work and repaint with fresh R81
-1st-gen Acura EL or 96-01 Coupe Side skirts
-07'-08' Acura TL-S or CSX-S trunk-lid lip spoiler
-new wheels (Trying to find my first love set of old 16" Spoon SW388's) but who know's...
-Reupholster the front Recaro's
-Sparco Harness bar
-Black Willans Harnesses with upgraded pull-down adjusters
-new main carpet
-Accessory lower dash console
-Hawk pads
-1" Master Cyl
-40/40 Prop valve
misc fixes and upgrades
Turbo Build:
B18c is being bumped up to 2.0L
Fully built (still deciding on parts)
Walbro pump
rail
fpr
ID 1000's
General components from a Peakboost kit (Tial WG/BOV)
-Upgrading to a PTE 6262 .82r
3" DP/Exhaust
Hondata S300
Tuned for this crappy 3500ft elevation
looking to put out 400whp on pump gas
ETC ETC ETC.... BLAH BLAH BLAH...
Can't wait to start yet another tear down and get down to business.
Hope you all enjoy.. Cheers!
To start...
General info:
Currently:
-SiR-S Cluster
-ITR shift boot
-Kenwood deck
specs on the motor:
JDM B18c GSR block
ARP Main Studs
ARP Rod bolts
ARP Headstuds
Honda Headgasket
JDM B18c GSR Head
ITR cams
Hondata I/m gasket
stock TB
K&N filter
Spoon plug-wires
2.5" test-pipe
2.5" T1R mid-pipe
Samco Hoses
-Sparco Harness bar
-new main carpet
-Hawk pads
-1" Master Cyl
-40/40 Prop valve
Turbo Build:
Walbro pump
rail
fpr
ID 1000's
3" DP/Exhaust
Hondata S300
spyderman_8_2
Jul 7, 2006 08:26 AM
92eg6
Apr 8, 2004 10:25 AM
