Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2004 Accord - four batteries in five years
Old Dec 6, 2011 | 05:40 PM
elposton's Avatar
Default 2004 Accord - four batteries in five years
i've had to replace the battery in my 2004 Accord 3 times in the last 5 years, and seeing the signs that the current battery is about to go (doesn't start on the first try - no clicking, just nothing. turn off and start over to get it going). all replacements - and 99% of service -- were done by Honda dealer. is there something that could be slowly draining the battery?? the last replacement was almost exactly a year ago . . . dealer service replaced some of the connections (? sorry I don't know the exact things) that they said were corroded and could be causing problems, but here i am a year later likely looking at needing another battery. help!
Old Dec 10, 2011 | 05:32 AM
lazlong's Avatar
Default Re: 2004 Accord - four batteries in five years
Make sure absolutely everything is off in the car. Dis-connect the negative battery cable. Take a test light and clip the lead to the negative battery post. Then touch the point to the negative battery cable. If the test light comes on when you touch the point to negative cable you have a parasitic draw somewhere.
Old Dec 16, 2011 | 10:29 AM
gwiffer's Avatar
Do you only do short trips? This can cause the battery to never get fully charged and fail sooner than normal.
Elton Lauring
Jul 26, 2018 11:49 PM
kksiddiqui
May 29, 2017 02:18 AM
patient49
Jun 29, 2015 05:46 AM
Pr0ject93hb
Classic Hondas
10
Jul 22, 2008 09:33 PM
LSracing94
Aug 19, 2007 08:07 AM
