Honda S2000 Honda S2000
Electrical problems on my S2000
Old Dec 6, 2011 | 05:17 PM
Lagoshooter's Avatar
Icon2 Electrical problems on my S2000
I have a cherry 2000 S2000 with only 36,000miles on it. I have owned it since new and taken great care of it.
Recently, out of the blue, major electrical problems have manifested. Soft top no longer working (stuck in down mode). Passenger window no longer working. Radio not working. Dome light not working. Electronic trunk opener not working ....
It started with the soft top and passenger window. I researched it and determined it was probably soft top controller. Then the other problems manifested, so I thought I had better take it to the dealer before I muck things up.
They were no help at all. They had no clue and wanted to charge me a fortune just to debug the problem.
They told me "no current was coming from the flex panel". Has any one heard of a "flex panel"? What is it? Where is it?
Could it be that my 12 year old battery needs replacing?
where do I begin?
Any advice on this one will be greatly appreciated.
Old Dec 6, 2011 | 05:25 PM
Black S2K's Avatar
Default Re: Electrical problems on my S2000
cherry is not a s2k color
Old Dec 6, 2011 | 05:27 PM
It is black on black. By "cherry" I meant "sweet', "nice", "hot", "cool"
Old Dec 6, 2011 | 07:32 PM
ITRbroham's Avatar
shit post warrior
Depending on where you live, check for damage from pests such as mice or rats chewing on wires.
Old Dec 8, 2011 | 04:29 PM
Sung@MM's Avatar
check all fuses w/ a DMM or by simply pulling it out, otherwise if all fuses are good, check to see if there is voltage present in the lines when you press the switch
Old Dec 8, 2011 | 05:09 PM
matt da jdm junkie's Avatar
Do you live near the philly area? If so ide love to take a look at it for ya. I have been a Honda technician for 5 yeas and i have an ap1 as well
Old Dec 8, 2011 | 05:21 PM
ok so i was looking at an etm for your car and a few of the symptoms you have described i would check ground g501 i attached a pic to help. that ground controls "Convertible top control unit, Cruise control main switch, Driver’s door key cylinder
switch, Driver’s door latch, Engine start switch, Gauge assembly (2 wires), Keyless
door lock control unit, Left headlight (low beam) (’04-’05), Passenger’s window switch,
Power mirror switch, Power window master switch, Radio remote switch, Rear window
defogger switch (’02-’05), Right headlight (low beam) (’04-’05)" hope this helps a little
File Type: pdf
Old Dec 8, 2011 | 06:14 PM
TJChad's Avatar
This...
primerisfiner
Feb 17, 2016 04:47 PM
baggelis
Honda S2000
Aug 10, 2008 04:18 PM
v8killacivic
Honda S2000
Feb 20, 2008 09:01 AM
IIGQ4U
Honda S2000
Mar 13, 2006 09:06 AM
Corpse
Honda S2000
14
Oct 7, 2001 01:11 PM
