Do I need the resistor box
Old Dec 6, 2011 | 05:16 PM
DillyD's Avatar
Default Do I need the resistor box
I have a 96 honda prelude Si. I did a JDM H22a swap and converted back to OBD1. It is currently running on a stock jdm OBD1 p13 ecu and runs well. I am swapping the ecu to a P28 chipped and I have been told I need to install the resistor box is this true? Not just because the ecu but just in general. Help would be amazing. Thanks in advance
Old Dec 6, 2011 | 07:50 PM
v4lu3s's Avatar
RTFM
Default Re: Do I need the resistor box
you already have a resistor box.
Old Dec 6, 2011 | 09:25 PM
typemismatch's Avatar
Honda owns me
x2
The injectors determine if you need a resistor box, not the ECU. When you change injectors, then worry about needing/not needing a resistor box.
DillyD
Dec 7, 2011 09:28 PM
jdmdikk
Apr 1, 2009 06:13 AM
raidacaipo
16
Feb 15, 2009 12:26 AM
on-site ej1
Dec 16, 2008 10:53 AM
blackntegra
Oct 29, 2006 11:49 PM
