215/50/15
i was curious if this wheel size would pose a problem for rubbing first of all. according to this calculator, they are right on for the speedo. i have a 2000 civic ex, not lowered, and wouldnt go below 1.5" drop
http://www.miata.net/garage/tirecalc.html
2nd, what size wheel would i need to mount these best?? would a 15x6.5 work or would it be better to go with a 15x7 or larger??
will most likely autox with my car in the spring, and planned on getting 205/50's but saw these matched the speedo even better
if anyone has experience running this size, let me know what you think.
i have searched and couldnt find enough to help me out
thanks, steve
thanks, steve
You shouldn't have many rubbing issues, as long as you don't go with a lower offset wheel. A 15x6.5 will work for them, as would a 15x7. Ideally, you won't want to stray far from a +42 to +35 offset.
thanks for all of the responses. im planning to stick to 14" wheels because tires are CHEAP!! just noticed the calculator was even, but i was guessing there was a reason there werent many people running that size
jxhxb
Nov 17, 2009 06:51 AM
hybrid_eg
15
Feb 10, 2003 12:59 AM
tysf
Aug 13, 2002 11:37 AM
