Civic has a hard time starting?
Old Dec 6, 2011 | 09:54 AM
8049710's Avatar
Default Civic has a hard time starting?
Hey guys I have a 500hp civic and it's has a harder time starting when it's really cold outside (15 degrees) but after a coupls of trys it fires up when it's warm it tarts no problem. I am just wondering if this is normal for built civic?
Old Dec 6, 2011 | 10:09 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Civic has a hard time starting?
Who knows? No one knows anything about your build other than it's 500hp.
Old Dec 6, 2011 | 10:33 AM
notsolfast's Avatar
Why are you running your 500hp civic in the cold? i have a swapped del sol i wont even run in the cold. Regardless, just do a quick check of all the normal things, (battery voltage, starter draw) But usually, older cars just take a little more to start up, especially heavily built motors.
Old Dec 6, 2011 | 11:25 AM
phat00civic's Avatar
I think the amount of power is irrelevant, but whatever. Does it make any noises when trying to start? ticking?
Old Dec 7, 2011 | 09:07 AM
dino1pilot's Avatar
Does it try to turn over or is it just turning the starter?
Old Dec 7, 2011 | 09:23 AM
The Grumpiest
Jeez. You haven't figured this out in two years?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/civic-hard-time-starting-2650863/
Old Dec 7, 2011 | 09:42 AM
Go_Race_Your_Self's Avatar
Two Piece
https://honda-tech.com/forums/showthread.php?t=2650863
Hahahaha
Anyway, it's cold out. Your motor is "built". It's fine. If it ain't broke, don't fix it.
Kev
Old Dec 7, 2011 | 10:38 AM
JgDsMr's Avatar
check your voltage drop on your engine/chassis grounds. grounds grounds grounds! + i would like to see this 500hp civ
Old Dec 7, 2011 | 01:15 PM
MonkeyMagic's Avatar
large injectors? probably
tuner probably used the injector modifier to make changes across all your tables to cut down the fuel at low/no throttle.
easy fix? yes! stuff a sock in the intake when you go to start it.. should help a little. or use starting fluid.
or change tuning to dump more gas at really low air/engine temps.
or just deal with the fact that it takes a few cranks to get the injectors to make enough of a gas puddle to allow enough burnable vapor to build up and start the car.
amillion3987
Honda Civic (2006 - 2015)
May 31, 2016 03:24 PM
b20hondacivic
19
Sep 2, 2012 01:41 AM
dukevt
Honda Civic (2001 - 2005)
Feb 11, 2009 12:08 PM
araya1624
Mar 3, 2008 08:07 AM
