Rebuilding B16a2 head...anything missing?
Im going to be rebuilding my B16 head due to leaky valve seals, noisier valvetrain, loss in a smooth rev, and a decrease in performance over time. Im going to be boosting the car in the future. Im going to retain the stock cams for now and put ITR/CTR cams in and then use those till and when i do go boost. Im going to get the head cleaned, Decked, and maybe a 3 angle valve job. Idk if its really worth much or not.
B16 Head
Oem head gasket
Oem Valve seals
Oem Valve keepers
Oem Valve Guides (If Necessary)
Oem Lma's
Oem Seats (If necessary)
Oem or Supertech valves (If Necessary)
Stock cams
Stock cam gears (until upgrade to ITR cams)
Oem or aftermarket timing belt
Is there anything im missing or should think about doing?
B16 Head
Oem head gasket
Oem Valve seals
Oem Valve keepers
Oem Lma's
Stock cams
im doing springs to freshen up everything in the head, plus i herd its common when valve springs get old and worn they get noisy, also ill be boosting and upgrading to ITR/CTR cams which dual springs are recomended. i already got a skunk 2 cam end plug, distributor is oem brand new, but new cam seals, and vtec gasket too ill add to the list.
vietdragontekx
Apr 19, 2006 09:04 PM
DelSolDon
Oct 5, 2005 04:58 PM
