Which OEM clutch?
Old Dec 6, 2011 | 07:49 AM
cletus11's Avatar
Default Which OEM clutch?
I need to replace the clutch in my LS. I need to stay with a OEM grade clutch because of my autocross class. I have read good things about the OEM Exedy kit (KHC05) but, also ran accross the Competition Clutch OEM kit. Does anyone have any experience with the Competition Clutch kit as a comparison to the Exedy kit?
Old Dec 6, 2011 | 08:53 AM
mouab18c1's Avatar
Default Re: Which OEM clutch?
Never owned a CC OEM clutch but I have owned an Exedy OEM clutch for almost 5 years now. I beat the crap out of it as well as daily driving.
Old Dec 6, 2011 | 09:10 AM
GagnarTheUnruly's Avatar
My Exedy has lasted longer than the stock clutch and engagement is very good. The pedal feel is kind of soft, though.
Old Dec 6, 2011 | 09:40 AM
DirtyDA9's Avatar
Exedy actually makes most factory clutches, not sure about Honda, but a lot of cars use Exedy from the factory.
Old Dec 6, 2011 | 10:23 AM
RecklessEJ's Avatar
EXCEDY FOR SURE !!!!!!!! i had such a great experience with the Excedy stage 1 organic clutch believe me the engagement was great and never complained about it i lov to run canyons and it never gave me a problem at all and held up well also its slightly stiffer than OEM i highly recomend it !!!!!!!!!
Old Dec 6, 2011 | 10:26 AM
OP needs OEM grade.
Old Dec 6, 2011 | 11:11 AM
racebum's Avatar
exedy or fuji carbon, the exedy is half the price. only difference between the two is the fuji has a slightly stronger pressure plate which you'll feel in the pedal.
for a stock ls, get the exedy oem. the clutch disc is what you're going to trash doing autocross. if it's legal the stage 1 would be ideal since it has a reinforced disc and much stronger pressure plate
Old Dec 6, 2011 | 12:02 PM
cletus11's Avatar
It has to be OEM. I am going to order the Exedy. Thanks for the input.
Old Dec 6, 2011 | 12:21 PM
cletus11's Avatar
The cheapest price for a Exedy OEM kit that I can find is $114 shipped on eBay. Does anyone know if I can get it cheaper somewhere else?
Old Dec 6, 2011 | 12:26 PM
racebum's Avatar
if that's from gripforce that's as cheap as you're likely to get, could always check amazon but gripforce is a wonderful seller
Old Dec 7, 2011 | 07:32 AM
cletus11's Avatar
Amazon is $109.
Old Dec 9, 2011 | 11:24 AM
mike703's Avatar
khc12 itr oem replacement. 96 bucks shipped from amazon
Old Dec 9, 2011 | 03:18 PM
cmwalker's Avatar
i have a BNIB oem clutch set for $100 shipped..pm for questions
Old Dec 10, 2011 | 02:44 AM
cletus11's Avatar
I already have one on the way.
Old Dec 10, 2011 | 04:34 AM
EsotericImage's Avatar
Retired Moderator
Exedy makes Hondas OEMs
07rebel
Honda Civic (2001 - 2005)
Oct 23, 2009 03:51 AM
jwhezzy2003
Aug 28, 2008 08:46 AM
98GSRDC2
Jul 8, 2006 05:12 PM
-[95cxhatch]-
Aug 4, 2003 11:06 PM
TypeSH
Mar 21, 2002 02:23 PM
