Front DS brake not releasing
Old Dec 6, 2011 | 05:00 AM
crex23's Avatar
Default Front DS brake not releasing
I have a 91 Civic LX and the front driver side brake is not releasing, its like its always on. The brakes are super-touchy, like they will almost throw you through the windshield when you apply moderate pressure.
The master cylinder was replaced before I got the car. I have replaced the caliper, pads, and brake line with new parts. If I remove the caliper, the wheel spins freely. If its on, the wheel drags.
The slide pins are also new, and greased well with brake lube. I am stumped on this one.
Old Dec 6, 2011 | 07:49 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Front DS brake not releasing
You replaced the line or hose? Also - the problem happened before or after you replaced the caliper?
Old Dec 8, 2011 | 01:27 PM
crex23's Avatar
The rubber hose was leaking so I replaced it. I replaced the caliper after it started sticking, thinking a new one would fix it. Unless I got a bad one from Oreillys.
Old Dec 9, 2011 | 05:10 AM
crex23's Avatar
Another thing I just now remembered, when I went to Oreillys to buy the caliper the guy told me that since my car is a 91, sometimes the parts overlap from one generation to the next. So he ordered me a caliper for a 92 Civic.
Have you ever heard this or is he full of ****? The caliper bolts up fine, the pads fit fine, everything fits.
Old Dec 9, 2011 | 05:03 PM
~sp33~'s Avatar
EFB055
Does the car pull to one side when you're driving, do you get vibration under brakes? I'm thinking that maybe a warped rotor is causing the rotor surface to jam between he pads as the wheel rotates.
96Formula6spd
Aug 25, 2011 05:39 PM
baller862
Honda Civic (2001 - 2005)
Dec 14, 2009 05:41 PM
Shaminda
Apr 4, 2006 12:20 PM
E_Bird
Aug 28, 2003 06:47 AM
ignitenj
Apr 28, 2002 05:47 AM
