Want to Buy Want to Trade/Want to Buy
Clutch going out!
Old Dec 6, 2011 | 04:58 AM
Fresh209's Avatar
Default Clutch going out!
Driving home last night from work at 1030pm, clutch had absolutely NO give in it (I barely place my foot on the clutch, and it hits the floor) and I had to force the car out of gear twice. 2000 civic DX wondering if there's any quick fix to look for? If not, any decent clutch recommendations and a ballpark of how much that+installation might run me? Had to steal wifey's car this morning to get to work!
Any info greatly appreciated. Thanks guys
Old Dec 6, 2011 | 05:15 AM
92CivicSiOEM's Avatar
Default Re: Clutch going out!
I have a stage 2 Clutch Master clutch and pressure plate....PM if interested!
Old Dec 6, 2011 | 07:12 AM
nasteboyii's Avatar
things to check first
clutch fluid may be low, if low most likely due to master cylinder leaking, and it leaks inside car slowly so hard to see over time
or slave could be bad, which can also leak
or clutch
i would start with the other 2 first, and there not much money or work, compared to doing a clutch
good luck
dan
Old Dec 6, 2011 | 07:27 AM
Fresh209's Avatar
Dan,
Thank you, I'll check both of those first. Thank you for the advice!
92CivicSi,
Haha thanks
Old Dec 6, 2011 | 07:56 AM
jrp355's Avatar
i have a competition stage 5 4 puck sprung clutch barely any miles on it. come with a lightened flywheel 262 995 8080
Old Dec 6, 2011 | 12:35 PM
guymosiris's Avatar
My clutch pedal hit the floor one time in a drive-thru, and would not return back up. I found out my clutch line was cracked. Check every connection in the system for leaks, although it sounds like your pedal returns back up.
Old Dec 6, 2011 | 01:52 PM
Fresh209's Avatar
Yeah it just hits the floor and then slowwwly comes back up like it's on its last breath.. If there's a leak, is it expensive to fix? Never had to deal with this before, but I need to get it fixed asap, so I'm kinda anxious about it.. sorry
Old Dec 6, 2011 | 04:14 PM
jrp355's Avatar
do you have enough fluid in the reservoir, is there a leak by your slave cylinder on the trans? sound definetly like you have a leak somewhere
mr. robot-o
Nov 9, 2008 06:27 AM
flatblackintegragsr
Mar 31, 2006 08:23 PM
jerBEAR
Aug 14, 2005 11:18 PM
range
Dec 1, 2003 02:01 AM
geminis2k
Nov 20, 2003 11:33 AM
