88 with 90 flywheel? help please!!
Old Dec 6, 2011 | 02:36 AM
rapom's Avatar
Default 88 with 90 flywheel? help please!!
ok so i started to feel my clutch slipping a bit the other day so i figure i had better start shopping around as i have never had to replace one before. from what i have read alot of people have had good luck out of both exedy and action clutch, so i am most likely going with one of those, but they looking at actions site it says that i need the 90+ flywheel.
so my question is can i use a flywheel from a 90+ on my 88? if not is there one that will work with the 90+ clutch kit, be it oem or an aftermarket light-ish weight one?
thanks in advance
Old Dec 6, 2011 | 08:11 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: 88 with 90 flywheel? help please!!
The flywheel will work just fine. The bolt patterns are all the same '88-00 SOHC engines - the surface area for the clutch disc is what changed.
Old Dec 6, 2011 | 08:14 AM
jlicrx's Avatar
the 90-91 flywheel will bolt onto the 88 engine, however, your problem is that the 88 transmission is not compatible with the 90-91 clutch disc - the 88 transmission has a 21 spline input shaft, which goes into the clutch disc - all 89-91 transmissions have a 20 spline input shaft - the 88-89 clutches are 200mm diameter with matching flywheel - the 90-91 clutches are 212mm diameter with matching flywheel - the 88-89 clutch assembly will not bolt to the 90-91 flywheel, nor will the 90-91 clutch assembly bolt to the 88-89 flywheel
what you need is the upgrade to the 90-91 flywheel and 212mm diameter clutch assembly with clutch disc having 21 splines - you can get the upgrade from ACT clutch which is pretty expensive or you can get an Exedy upgrade for the 88 which has the 212mm clutch assembly and matching flywheel with clutch disc having 21 splines - go here:
http://www.clutchcityonline.com//products/08-709.shtml
Old Dec 6, 2011 | 08:20 AM
DO IT ON ALL FOURS
I think that was more confusing that it was worth... Here is a link to your guide "jlicrx" that "Tyson" did...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/stock-clutch-fitment-guide-2284956/
PS - I guess I failed to mention the pressure plate won't bolt to it - but you can use the clutch disc as mentioned above.
Old Dec 6, 2011 | 10:14 AM
stackedhouse's Avatar
You can just use the 88 tranny with a 90-91 flywheel and use an 86-89 accord clutch disc you need the 90-91 pressure plate
Tyson
May 3, 2008 11:21 PM
tuname420
Aug 31, 2006 09:44 PM
DA91TEGGY
Jul 22, 2005 01:19 PM
pisetup
15
May 30, 2004 02:08 AM
tylerdurden
Jan 31, 2003 10:54 AM
