98 civic 4x100 to 4x114.3
Old Dec 5, 2011 | 12:15 PM
98EJ7Y8's Avatar
Default 98 civic 4x100 to 4x114.3
http://cgi.ebay.com/ws/eBayISAPI.dll...ht_6777wt_1025
http://www.ilovebodykits.com/product..._1mm_Bore.html
please check these two links and tell me if anyone would run this setup .. i know wheel adapters aint the best to do but i really like the rims and im willing to do what i have to
Old Dec 5, 2011 | 12:33 PM
toyomatt84's Avatar
Sanji
Default Re: 98 civic 4x100 to 4x114.3
That should work just fine, as long as you're not running extended lug studs.
Old Dec 5, 2011 | 12:36 PM
98EJ7Y8's Avatar
THANKS!! but with the offset being +47 and the adapter being 25mm thick would the rim stick out of the wheel well any ??
Old Dec 5, 2011 | 02:52 PM
toyomatt84's Avatar
Sanji
If you do the math, it'll be a +22 offset, which will put you close to the fenders/quarter panels. If you run a little bit of negative camber, or roll the fenders/quarter panels, you'll be fine.
Old Dec 5, 2011 | 03:39 PM
98EJ7Y8's Avatar
i hate to sound stupid but what is rolling the fender or quarter ?? and i wouldnt want any negative camber unless its only like a small amount
Old Dec 5, 2011 | 06:26 PM
TunerN00b's Avatar
http://www.google.com/search?q=fender+rolling
Um, the car came with some negative camber, and you most certainly do want some.
Define "small amount" for us.
Old Dec 6, 2011 | 07:00 AM
98EJ7Y8's Avatar
[QUOTE=TunerN00b;46469812]http://www.google.com/search?q=fender+rolling
I guess ur right .. I don't want anything noticable from behind the car . And I looked it up i was hoping someone would explain a little .. is the only thing u do is bolt up the roller and basically go to town maybe with some heat , of course taking time ?? Or is there more involved
.. imo I think the rolled fenders look good on lowered cars with the right rim and tire choice
Old Dec 6, 2011 | 10:31 AM
TunerN00b's Avatar
Yes, bolt it on, bend the metal, and try not to destroy the paint.
Old Dec 12, 2011 | 08:59 PM
OCwheellover's Avatar
heat the the fender so the paint wont crack. its always good to have someone who has experience with fender rollers. You can always use a rubber malet and hammer it slowly.
Old Dec 13, 2011 | 04:37 PM
jonathan2006's Avatar
you may have to trim your lug studs down some if they stick out of the adapter. this way the wheel will sit flush on the spacer.
Old Dec 16, 2011 | 06:20 AM
xl1lxbustax's Avatar
^^ some wheels have spaces by the lug hole in them so you can run the spacers if the original studs stick out pass the adapter.
Climbtrees
Mar 23, 2011 11:07 PM
pornstarcivic
Nov 10, 2009 11:05 AM
turnsignalandy
Jun 24, 2007 09:19 PM
KCHybrid
11
Apr 4, 2003 08:46 AM
JeffS
Mar 13, 2003 05:24 AM
