Just installed 4.7FD got a question
Old Oct 7, 2002 | 03:50 PM
WhiteTeg2000's Avatar
Default JDM 4.7FD help!!!
Last week i had an ACT 6-puck and Xtreme pp put in as well as spoon flywheel and JDM 4.7FD. I Drove around for about 250 miles to let everything set in good.
Now im starting to get slight gear whine.
I have heard stories about the ATS 4.9 whining but never the jdm. Is this Normal??? Did i not let it break in long enough or something.
Also my shifter seems to be warmer than usual. Im thinking the fluid might be low not sure though. I wont be able to check it till tomorrow.
Anyone have any ideas??
[Modified by WhiteTeg2000, 1:45 AM 10/8/2002]
Old Oct 7, 2002 | 04:46 PM
Default Re: JDM 4.7FD help!!! (WhiteTeg2000)
ttt
Old Oct 7, 2002 | 06:24 PM
sackdz's Avatar
Describe the gear whine please. My JDM FD felt the same as stock, no extra noises.
As for the warm shifter, I think you're imagining things. The shifter is far away from the transmission and any "heat" from the tranny wouldn't ever make it down the linkages for you to feel. The shifter is warm because the exhaust goes right under it.
Old Oct 8, 2002 | 12:23 PM
Default Re: JDM 4.7FD help!!! (sackdz)
checked fluid level this morning and it was 3/4 quart low - when i pulled the check level bolt off it was completely dry. i called the tranny shop and scheduled to drop it off for them to pull apart and check. im pretty sure a bearing has gone bad or something similar.
car sounds like a sequencial shifter in a rally car. its whining like crazy under acceleration. im sure its something really bad and expensive. Thats my luck!!
Old Oct 8, 2002 | 12:28 PM
ITR21's Avatar
Thats my luck!!
TRUST ME i know how you feel
Old Oct 8, 2002 | 12:57 PM
GRM Scott's Avatar
25 Year Member
my ATS sounds no different than stock, apart from the revs climbing faster
Old Oct 10, 2002 | 07:05 AM
Default Re: JDM 4.7FD help!!! (Aleph)
got the tranny apart - found out a bearing went bad on the input shaft. No big deal but the car is down till the weekend.
Sucks for me
shaundesjardins
19
Jul 26, 2012 11:54 AM
BHC
Jul 18, 2010 11:21 AM
sean2000gt
Dec 15, 2008 08:59 PM
tomato_man
10
Apr 15, 2007 06:56 PM
JM Performance
Nov 22, 2001 12:32 PM
