1991 Civic EX Sedan random question
Old Dec 4, 2011 | 07:11 PM
†Hoar†'s Avatar
Default 1991 Civic EX Sedan random question
Can an 89 integra hood fit on a 91 ef sedan? :/
Old Dec 4, 2011 | 07:35 PM
BiG ChOr!Zo's Avatar
Default Re: 1991 Civic EX Sedan random question
no
Old Dec 4, 2011 | 09:51 PM
89civicstd's Avatar
no your better off getting a 90 or 91 sadan hood
Old Dec 4, 2011 | 11:05 PM
†Hoar†'s Avatar
Well.. do they make a raised hood for it? (that's relatively cheap?)
Also, i was told that on the stock bumper, there is a place that's already marked to cut out for fogs and that prelude fogs would fit in there nice and snug. Can someone confirm that, and tell me what year fogs of prelude i'd need?
Also (i hope this is the last one).. I lowered my car and the front is bouncey, but i can push on the front of the car and the car will still do up and down, but when I lowered the back, they are stiff as hell. Almost no give, just all bounce on ever pebble i hit. Will new rear and front struts fix that and make it a decent ride again? Or am I screwed?
Old Dec 4, 2011 | 11:08 PM
zc dohc hood
88-89 prelude fogs
front shocks are blown=replace
Old Dec 4, 2011 | 11:11 PM
†Hoar†'s Avatar
The fronts are blown??? :O That's the smother ride of the two (front and back). What will fix the extreme bumpyness is what i wanna know. Can i wear out mah rears in a fast way? xD
Old Dec 4, 2011 | 11:13 PM
†Hoar†'s Avatar
How hard is it to put disk brakes on the rear? A pain, or not that bad? I wanna look into that.
Old Dec 4, 2011 | 11:36 PM
codybuRr's Avatar
its not too hard, just make sure you have all the right parts before you start
Old Dec 5, 2011 | 08:42 AM
†Hoar†'s Avatar
What about the really bumpy ride though? If my front struts are blown, but that's the smoother ride between the front and the back, do i need/want to change the front struts? Or is there something that i can/could do to the rear to make it not so stiff. It's bad enough that it's not even enjoyable to to drive right now.
Old Dec 5, 2011 | 08:53 AM
crvtectim's Avatar
Are you sure you didn't mix up springs accidentally and install your fronts on the rear and rears on the fronts?
Old Dec 5, 2011 | 08:56 AM
89civicstd's Avatar
Try some coilover that's what I did with my ride it use to.sound like it was going to brake down so I slap on some coilover and its stiffer and I ca also adjust the hight
Old Dec 5, 2011 | 09:10 AM
julioboostamante's Avatar
see below
Old Dec 5, 2011 | 09:14 AM
Holy hell.... I can't understand you guys or your grammar.
I'm guessing both of you were too busy sniffing glue. Let me guess, you went to the same school?
Old Dec 5, 2011 | 09:16 AM
lunalink's Avatar
just read the faq y0!
Old Dec 5, 2011 | 10:08 AM
†Hoar†'s Avatar
I bought coilovers. That's what's on there now. They weren't labled for front or rear, they were all the same exact springs. i can/could adjust it higher, but that would defeat the point of me getting the coilovers to lower the car. I like the way the front rides, as i said. it's a smoothe, not so bumpy ride that i can enjoy. the back though is like i put f'n 2x4's as the springs. there is no give, or anything. just extreme bounce for no reason. that's what i'm wanting to fix. or can i..
Old Dec 5, 2011 | 11:35 AM
4drEF's Avatar
Keyboard Humorist
no your better off just getting an Integra
FTFY
Old Dec 5, 2011 | 12:11 PM
†Hoar†'s Avatar
...thank you for that brilliant answer.
Old Dec 5, 2011 | 02:06 PM
crvtectim's Avatar
Spring rates are different from front to rear, dude. I have coilovers too. The springs look identical. However, the spring rate up front is 10k while the rear is 6k. Try switching them around.
Old Dec 5, 2011 | 02:46 PM
†Hoar†'s Avatar
http://www.amazon.com/88-00-Honda-Co...3128760&sr=1-1
This is what I bought, you sure there's a difference? Lol.
Old Dec 5, 2011 | 03:11 PM
you went from worse to worse...hopefully you buy a set of decent adjustable shocks...!!!
Old Dec 5, 2011 | 10:33 PM
†Hoar†'s Avatar
i was hoping i wouldn't get that answer. xD
Can anyone find a site that I can get better shocks/struts or wtf ever. :D
Old Dec 5, 2011 | 11:35 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Koni/ground control.
Old Dec 6, 2011 | 11:32 AM
†Hoar†'s Avatar
That's not expensive? xD
Old Dec 6, 2011 | 01:31 PM
crvtectim's Avatar
Op, blown shocks in the rear will not make your car feel like it has 2x4s for shocks. Blown shocks would give you more of that floating-on-air, cushy ride that you seem to like with your front suspension. Before dropping coin on new struts/shocks, contact the manufacturer of that high dolla suspension you got and ask them if their spring rates are the same front and rear. And remember this:
Mod cheap = Mod twice.
sodaZC
11
May 14, 2014 10:45 AM
gnxpro24
Jun 9, 2013 11:58 AM
Hawkze_2.3
Jan 28, 2007 12:40 PM
92accordexpower
Dec 5, 2004 02:06 AM
Mr. Thunderlips
Jul 31, 2002 04:36 PM
