Mpfi swap problems please help!!! PLEASE I NEED MY CAR FIXED!
ok guys i have a 88 ef sedan lx i just converted to mpfi and obd1 I have checked my wiring and can't figure out my problem it seams to run decent at low RPM's around 3k. But if i get over that it starts like falling on its face like stops pulling it backfires and shuts off I'm throwing a code 4, code 7, code 9, and code 15. I've tried 2 new distributors and still does the same thing. Can someone please give me some idea's. Thanks for any help that I recieve.
Code 4 Crank position sensor
Code 7 Throttle position sensor
Code 9 No.1 cylinder position sensor
Code 15 Ignition output signal
I would recheck your MPFI wiring conversion and check your mechanical timing along with the ignition timing since you've replaced the distributor twice.
Ive searched but cannot come up with detailed discription (pictures included) about how to do the DPFI>MPFI>Obd-1 swap. Anyone? Sorry to highjack back on topic.... Id check your distributor wiring again....
There's a guy that literally just posted up a DPFI to MPFI guide. OBD1 conversion you can buy wiring harness connecters for the dizzy.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/my-dpfi-mpfi-writeup-2994327/
http://hondaswap.com/swap-articles/d...writeup-49557/
http://www.google.com/#sclient=psy-a...w=1366&bih=595
I'd say the problem must be in your wiring since the cps is located inside your distributor and you say you've tried 2 other good distributors and get the same results. Double check your wiring to your distributor. What ecu and distributor are you running?
scottso990
10
Aug 2, 2010 12:54 PM
CRseX84
10
Jun 19, 2004 05:57 AM
