mini swap Water pump? timing belt
Old Dec 4, 2011 | 02:23 PM
B18B1-Crx's Avatar
Default mini swap Water pump? timing belt
Okay were almost done im pretty sure we have to get another water
pump
Right now we have the stock d15b1 19 tooth water pump
we have a d16y8 and a d15b1 timing belt
The d15b1 timing belt is too long
The d16y8 timing belt is too tight
What the **** is up Water pump?
Old Dec 4, 2011 | 02:36 PM
B18B1-Crx's Avatar
Default Re: mini swap Water pump? timing belt
bump hurry please parts stores about to close
Old Dec 4, 2011 | 05:22 PM
90civic-ZC's Avatar
A timing belt cant be too tight unless you mean you cant fit it around the cam gear. Use the water pump for the block you're using
Old Dec 4, 2011 | 07:37 PM
B18B1-Crx's Avatar
Never mind sorry i got
Ennis555
Apr 11, 2017 09:21 PM
globy123
Aug 8, 2008 08:38 AM
njracer
Jan 10, 2008 05:07 PM
1998hondaaccord
Sep 18, 2003 05:00 PM
