Old Mar 25, 2015, 09:22 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
How to bleed Power steering?
Old Dec 4, 2011 | 11:52 AM
William1991b's Avatar
Default How to bleed Power steering?
I'm hear a grinding sound when Im turning steering wheel. I replace my power steering hoses. So im thinking air got in it. But im not sure how to bleed it or how to take the air out.
tutorial with a video would be nice =D
Old Dec 4, 2011 | 05:10 PM
Default Re: How to bleed Power steering?
70+ views and noting -_-
Old Dec 4, 2011 | 06:52 PM
6_Speed's Avatar
Make sure there's adequate PS fluid in the reservoir. Put the car in park, rev the engine to a fast idle (I used 1500 rpm) and turn the wheel from one extreme to the other while avoiding full lock. Do this several times, then return to center and let the car idle normally for a couple of minutes.
Check all the hoses, especially the suction hose (inlet) and make sure they are pushed in far enough and securely clamped.
Old Dec 4, 2011 | 07:07 PM
10psiLsEf2's Avatar
Air in the power steering pump/system wouldnt make a grinding noise. MAYBE a whine and stiff steering.
But like mentioned above turn car on hold rpm at around 1500 rpm and turn the wheels all the way left and all the way right back and forth. (dont go to the very max were you feel the rack wana burst lol!
if it doesnt go away id start saving for a new pump.
Old Dec 4, 2011 | 08:15 PM
nus_dogg's Avatar
Just top the resevoir to the max line and steer the wheel from lock to lock. Doing this will bleed the system.
Usually when it whines, fluids low. Otherwise the pump may be on it's way out.
Old Dec 4, 2011 | 08:46 PM
6_Speed's Avatar
If there is air getting into the inlet, the pump will make a buzzing noise, which gets louder as you turn the wheel. You'll see foam and bubbles in the reservoir as well. Since you replaced the hoses, they should not be a contributor. There is an o-ring in the inlet fitting of the pump that could potentially leak air into the system.
bobsacomano
Honda CR-V & Element
Nov 8, 2015 01:08 PM
avargas28
Jan 12, 2009 09:09 AM
CWBETB
Mar 27, 2008 03:08 PM
JBirch_97Prelude
Dec 6, 2007 07:53 PM
