obd0 and obd1 1 wire 02 sensor same?
Old Dec 3, 2011 | 07:54 PM
JohnnyEF's Avatar
Default obd0 and obd1 1 wire 02 sensor same?
Are obd0 and and obd1 1 wire 02 sensor interchangeable? I found a 1 wire 02 sensor from my EF crx and wanted to know if I could use that on my EG cx which has a 1 wire 02 sensor.
Old Dec 4, 2011 | 11:20 AM
JohnnyEF's Avatar
Default Re: obd0 and obd1 1 wire 02 sensor same?
bump
Old Dec 4, 2011 | 11:38 AM
JDpower's Avatar
How is the Eg obd1 o2 a one wire? I thought all obd1 o2's switched to 4 wire heated o2. I would think if they are both 1 wires they would be interchangable.
Old Dec 4, 2011 | 11:46 AM
Former User's Avatar
The OBD1 D15B8 engine apparently had a 1-wire O2 sensor.
Old Dec 4, 2011 | 12:49 PM
90civic-ZC's Avatar
yes it will work as long as it's the same size.....which if it is a one wire O2 sensor in the car, they were all the same
Old Dec 4, 2011 | 01:14 PM
crx_si-r's Avatar
i believe it was the CX model that came with a 1 wire o2 sensor
Old Dec 4, 2011 | 03:21 PM
JohnnyEF's Avatar
Yes my cx came with one a one wire 02
JohnnyEF
Dec 4, 2011 03:18 PM
claytonsmith
May 11, 2006 09:43 PM
Mach69
Dec 21, 2004 08:16 PM
