Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Are these spark plugs worth it?
Old Dec 4, 2011 | 08:29 AM
EM2Ninja's Avatar
Default Are these spark plugs worth it?
I use my car as a daily driver. I don't drive it hard. I don't redline every single time. Never hit the rev limiter. Would it be worth it to buy these spark plugs?
Just trying to have my car run well. I don't care that it says 12% performance gain or anything like that.
Thanks
http://sparkplugs.com/more_info.asp?...3228&pid=41404
Old Dec 4, 2011 | 08:49 AM
toyomatt84's Avatar
Sanji
Default Re: Are these spark plugs worth it?
It's best to use plugs recommended by Honda. NGK PZFR6F-11 or DENSO PKJ20CR-M11
Old Dec 4, 2011 | 10:05 AM
EM2Ninja's Avatar
Is it bad to use a better performing plug?
i.e ZFR6FIX-11
Old Dec 4, 2011 | 10:10 AM
It Wasn't Me's Avatar
Using the wrong plugs can cause issues. I've seen it happen many times. It's best to just stick with the recommendation.
Old Dec 4, 2011 | 10:19 AM
civicexbully96's Avatar
i usually
ngk iridiums or go to procivic.com and thats what makes my car run way better.
Old Dec 4, 2011 | 02:56 PM
postman's Avatar
stick with factory plugs. using anything else is asking for misfire issues. only time to use a different plug is when you have modified the engine greatly.
Old Dec 6, 2011 | 11:40 AM
rohaansaeed's Avatar
I'd suggest you buy NGK Iridium IX, ZFR6FIX-11
or if you don't want to spend much, get the NGK Platinum, PZFR6F-11, these are mostly recommended for our Civics.
pfork
Jun 22, 2007 07:37 PM
Woogie Ctr
Apr 11, 2006 08:47 AM
Markov
Oct 7, 2005 10:33 AM
Greg James
Aug 18, 2004 05:18 AM
JDlvl InTEGRA
Feb 6, 2003 04:48 PM
