94 accord putting when barley on the pedal
Old Dec 3, 2011 | 09:31 PM
accord94cd7's Avatar
Default 94 accord putting when barley on the pedal
Hello I am new and first wanted to say hello..I got a 94 accord with the f22b1 now when I drive and barley push the gas pedal in the car makes a putt putt backfire type noisebut if u give it a little more gas it stops..I can be doing 60mph and lightly touch the gas and it will do it.....I replaced the tps with a used one, new distributor and botton, used but good wires and new plugs, new coil pack put whole can of seafoam injector cleaner in the tank and still does it....any ideas??
Old Dec 4, 2011 | 02:00 AM
holmesnmanny's Avatar
Default Re: 94 accord putting when barley on the pedal
The tps needs to be calibrated. Is the car throwing any codes ?
Old Dec 4, 2011 | 09:10 AM
i didnt think the tps needed to be calibrated since it is used off a different car but same specs but the car was doing it even with the stock tps on then i replaced it with the current one thats used. i just jumped the wires to check the ecu codes and when i turned the car on the CEL light came on and stayed soil lite for over a minute until i turned the car off.
Old Dec 4, 2011 | 09:46 AM
v4lu3s's Avatar
RTFM
what happens when you put corn on the pedal instead of barley?
if your check engine light is on then you need to pull the codes. thats why its there to tell you whats wrong. if you replaced a tps you have to calibrate it since it must be .5 volts closed and 4.5 volts open and that number changes based on how the3 tps sits in the throttle body.
Old Dec 4, 2011 | 09:48 AM
Lost Again's Avatar
Did you replace JUST the tps or the entire tb? If it was JUST the tps then you know it is "slotted" alowing for adjustment (that is why the factory on is rivited on-it is set to spec's). It is something like .5v closed, ~4.5v wide open.
Old Dec 4, 2011 | 11:11 AM
HonBeer's Avatar
Barley is a major cereal grain, a member of the grass family. It serves as a major animal fodder, as a base malt for beer and certain distilled beverages, and as a component of various health foods.
Old Dec 4, 2011 | 01:09 PM
ok guys heres what i did to fix it...it was the egr ports 3 out of 4 where clogged really bad and even under the actual egr valve was clogged..ty for all your input and help with this issue..is was actually really easy to clean..took more time cleaning then acutally taking the fuel rail off.. but ty all who actually helped with the issue instead of talk crap about a grammar error keep up the good work
Old Dec 4, 2011 | 02:31 PM
poorman212's Avatar
FIXED... .....good job!
Please double/triple check there are no leaks from the injectors...please.
EDIT: Don't let the haters get you down...hold your head high and be proud and respectful and things will be fine.
Old Dec 4, 2011 | 05:41 PM
I just checked a while ago and everything is good....I will check again tomorrow ....again ty all
Old Dec 4, 2011 | 08:33 PM
nus_dogg's Avatar
I was just gonna say it's your EGR ports that are clogged. Same sh*t happen to my F22B1 I had back in the day. It would sputter when I'm on cruise throttle.
Old Dec 4, 2011 | 11:34 PM
I gotta think he meant TB instead of TPS but whatever. You can only help those that want it.
Old Dec 5, 2011 | 08:11 PM
no i meant TPS which is your throttle position sensor, i replaced the actual sensor instead of the whole TB but that wasn't the problem. all is well now it is fixed..ty
Old Dec 5, 2011 | 10:33 PM
lol I think I know what a TPS is. I don't think you know what it does or how to calibrate it tho. gg
Old Dec 6, 2011 | 10:28 PM
L.a.'s Avatar
so your check engine light stayed on the whole time ? i think my car is doing the same yours was doing. here is what mine is doing skip to 0.50sec :
http://www.youtube.com/watch?v=NPWog...layer_embedded
Old Dec 7, 2011 | 11:49 AM
L.a.'s Avatar
anyone?
Old Dec 9, 2011 | 05:16 PM
Lost Again's Avatar
Might want to start your own thread.....What have you done, prior to this or after it started.
MOD's Please move this to a new thread.
76 camaro car
Aug 3, 2015 12:20 PM
STi-Thrill
Feb 16, 2011 11:27 AM
billyjo
Jul 6, 2009 05:00 PM
CLMTFabEG6
Mar 13, 2007 08:34 PM
vtechon
Apr 20, 2002 11:33 PM
